SOURCE: mogen tv remote control code
can you please assist us with a Sky setup code for Neovia neo-3775nd.
SOURCE: VIZIO vx37l tv remote control code for cox tv remote
0178 will work but you have to keep the set-up button pressed down for more than a few seconds after you press TV on your cox remote. (You will see the tv button light up 2 or 3 times after pressing it and holding the set-up button down)
SOURCE: remote code for nexus television
The only ones I can find are 0463 10463 and 720. If these don't work you could try the auto find method below. As the remote appears to only accept 3 digit codes I'd try 463 and 720. These are known to work on dtv and comcast for this model.
STEP1 Turn on the Component you want to
program (TV, VCR, DVD or AUX).
STEP2 Press the [COMPONENT] button (TV,
DVD or AUX) to be programmed and
[OK/SEL] button simultaneously for 3
seconds. The Component LED will light
for 30 seconds indicating the unit is
ready to be programmed.
STEP3 Point the remote toward the
Component and press the [CHup] or
[CHdn] button one step at a time or
keep it pressed. The remote will emit a
series of ON/OFF commands. Release
the [CHup] or [CHdn] button as soon as
the Component turns Off
STEP4 Test functions. (Same as for 3-Digit Code
Programming Method - Section A). If any
of the functions do not work as they
should, repeat from STEP 3 using [CHup]
or [CHdn] buttons to find the correct code.
STEP5 Save the code.
SOURCE: need code for remote control
To program a TV you can use the code search option. You do this by making sure the TV is turned on then point the remote at the TV then press the TV button once, then press and hold down the set button until you see the RED l.e.d light blink twice, then enter the code 991. Next press the power button then the TV button continue doing that until the TV turn off, when it does press the set button. Press the power button and the TV should turn on again.
SOURCE: Tv Code for Time Warner Cable Remote
I need got a different tv tan i had when my tv was installed s i need the code
