SOURCE: 220 watt car amp -- 8 or 10 gauge amp kit?
when in doubt go bigger, you might want to get a bigger amp down the road, so its better to not have to buy another wiring kit later.
and the bigger the wire the less line loss you will have so your amp will sound and perform better.
SOURCE: I have a Jensen A222HX amplifier. I want to hook a subwolder to it. How do I bridge the connection
Hello rcell66,
The Jensen A222Hx is an "old school" amp and the channels are probably not bridgeable. I'd recommend posting and/or researching your question on one of the "Car Audio" forums. Many of the members are old school trained and may even be able to locate a manual for Jensen's.
Hope this helps.
SOURCE: Have Jensen A1000 how do I bridge it?
that model amp if am not wrong dont need to be bridge its a mono block amp
SOURCE: i have 4/3/2 ch. alpine f-240 amp- i want to hook
run two 6x8s on each of the front channels of the amp. then depending on the sub you can bridge it on the rear channels.only if its a single four ohm. if its a dual 2 ohm sub run each coil on each channel. 1 coil-1channel. the other coil-the other channel. amp should run fine may run a little hot since it will be doing all it can do at a safe ohm load. just make sure it is mounted in a well vented area. should be safe.
