Vacuums Logo
Keith Ramirez Posted on Dec 22, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Riccar vibrance R20E Unit will not turn off at the power switch, need to unplug.... Any ideas
Thatvacguy.com
Level 3:
  • Riccar Master 1,619 Answers
  • Posted on Dec 23, 2017
Thatvacguy.com
Riccar Master
Level 3:
Answers
1619
Questions
0
Helped
605009
Points
3345
The most likely thing is you need a new switch
1 Related Answer
Anonymous
  • 25 Answers
  • Posted on Mar 26, 2008
SOURCE: riccar rc1100 won't turn off
I am an riccar dealer, and you either have a short in the wire leads from front of vacuum to circuit board or a bad circuit board which if so the boardd will have to be sent to manufacture to be rebuilt as there are no new circuit boards available. if not under warrenty which i doubt since riccar hasnt made these models for a while. would recomend replacement with either sunburst or moonlight model as they are a comparable replacement to the repair. or just simply just plug and unplug machine, if it doesnt bother you to do so. If more questions email me at [email protected] subject riccar, or go to www.riccar.com to locate nearest dealer
My Riccar 1800 won't turn on all of a sudden.
Question edited for clarity and spelling of maker.
Question moved from TX Watches category.
Try the thermal reset again. When you are using the vacuum and then turn it off, the motor is hot and there is no cooling airflow. If the vacuum is close to cutting out through overheating that lack of air will trip it. If you have digital multimeter, you can check the thermal switch for continuity.
https://www.google.com/search?q=Riccar+1800+won%27t+turn+on
Riccar 8850 Upright Vacuum Cleaner. I need a wiring diagram for it please?
Question edited for clarity and typo.
There is no wiring diagram available
https://www.google.com/search?q=riccar+8850+wiring+diagram
There is a video though
Or you could ask the maker?
Vacuum Cleaner Operating Instructions
Riccar http://media.riccar.com > 8000_Owners_Manual
How to Replace the Agitator Belt. (Models 8750 8850 & 8800 only). Unplug the units power cord. Turn the unit over and remove the bottom plate as described in ...
13 pages
Why does the belt on a riccar vacuum keeps coming off?
The cause could be different depending on which model you have. Some models have stretch belts which should be replaced at least once per year because they lose elasticity. The most common problem I've found with Riccar vacuums is the belt coming off when a new belt is installed on an older model. Riccar vacuums are very well built and many owners use their vacuum for many years without having it serviced. I recently had a 17 year old Riccar Vibrance model brought in for service because the belt crumbled to pieces. The vacuum had the original belt and filters. Putting a tight new belt on the vacuum pulls on the motor because it must be stretched so much. After many hours and years of use screws may need tightened up and motor mounts and pivot points can become worn.
If your model is a few years old or is used heavily I suggest having it inspected by a qualified Riccar service center. A properly maintained Riccar vacuum can last 10 or even 20 years. A few dollars spent on maintaining it can add years to the usable life.
How do you replace a vacuum hose on a Riccar upright Vacuum.
Riccar Tandem Air models have a hose that has releases to push to remove the hose. Most Vibrance & 8000 series and older series vacuums have the hose attached to a swivel on the back of the vacuum. The hose can be unscrewed from the swivel. To remove the swivel you need to remove the vacuum bag inside the dust compartment, you must compress the tabs holding the swivel to the body to be able to pull it out.
Replace bearings on riccar vibrance
The bearings in the brush roll can be replaced if. It has the metal brush roll. Remove the cotter pin to remove end caps and remove the shaft. Remove the plastic bearing holder on the belt end or the metal bearing holder on. The other end.
Riccar vacuum Moon 1 just won't turn on, any ideas?
Check cord, esp at entry point. Otherwise it may be switch, motor windings burnt out, broken wire, carbon brushes worn. Some appliances also have a thermal fuse, which is a silver tube shape.
I have a riccar vibrance red vacuum, just purchased with in 6 months and the roller brush wont go on and the reset button doesn't seem to push in or work I now live in Hankinson, ND 58041...there is a...
The reset button only pops out if the vacuum motor overheats. It does not affect the brush roll. If the motor is running the problem is most likely a broken or stretched belt.
4helpful
Stopped running. Filter was clogged. Cleaned filter and changed bag, but still won't start. Motor was warm when it stopped.
Hi There,
This sounds like the Thermal Switch in your motor tripped. All Riccar vacuum cleaners have a motor reset switch, that will shut the motor down when it gets hot. Usually it's caused by a full bag, clog, or dirty filter.
Try resetting the thermal switch first. If this doesn't work, you may have done some more serious damage to the motor, and it might be a good idea to take it into a local Riccar dealer in your area.
Here's a step by step guide on how to check the reset switch on your Riccar 8850:
To reset the thermal fuse:
  1. Unplug the vacuum cleaner
  2. Check for problem – over–filled bag, clog in hose, clogged filters, etc.
Remove the vacuum bag, and see if you can visibly see any obstructions, or replace the bag if it's full:
Also inspect the Secondary filter while you have the vacuum bag removed from the machine. If the filter is clogged or dirty, rinse under warm water, and air dry completely before reinstalling it into the vacuum. It's best to wash this filter every 30 days, and replace after 4-5 washings.
Here's a link to the secondary filter on our website if you ever need to purchase one:
Riccar 8800 Series Secondary Filter
Your Riccar 8850 also has a set of exhaust filters that are on the front of the vacuum, near the bottom where the upright body meets the agitator housing. These filters when clogged may also cause the thermal switch to trip. These filters are recommended to be replaced every 6-12 months, and are not recommended to be washed.
Here's a link to 2 sets of the exhaust filters for the Riccar 8850 on our website:
Riccar 8850 Exhaust Final Filters, 2 Sets, 4 Total Filters
It's also possible that you may have clog in the suction port inside of the agitator housing. Remove the bottom plate from the vacuum, and look for the tube that runs on the left hand side from the tray to the rear of the agitator housing. Make sure that this tube is clear from obstructions:
Locate "tripped" fuse – the small white button located on the bottom of the back side of
the main body (roughly one inch to the right of the left wheel)
Using a pencil, paper clip or other pointed object, push the reset button in, you should hear a clicking noise when it resets.
Plug the vacuum cleaner back into the wall, and try turning the vacuum on. It should come right back on. If not, it's best to take your machine into a local Riccar authorized repair facility for further more advanced diagnosing.
Please feel free to ask any follow up questions by adding a comment to this repair, I'm always more then happy to answer any and all follow up questions if you need some clarification. If this was helpful, please rate the repair helpful or leave some feedback for me. Thanks so much,
Chris Jones
Govacuum.com
Riccar 1700 power nozzle wont turn on
Make sure the 'Power brush' switch on the contol panel on the hose is depressed. Check the circuit breaker on the power nozzle; it will either be a button or a breaker that looks like a rocker switch, try to reset it.
Is the power nozzle motor running but the brush just isn't turning? If so you may have a broken belt. Not a likely solution since the belt is a lifetime belt, but still remotely possible.
1helpful
Riccar rc1100 won't turn off
Top Riccar Vacuums Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
