Garbage Disposals Logo
T
Tom Rectoe Posted on Dec 22, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unclogging garbage disposal - Garbage Disposals
Jean DeLauche
Level 3:
  • Master 2,911 Answers
  • Posted on Dec 22, 2017
Jean DeLauche
Master
Level 3:
Answers
2911
Questions
Helped
975865
Points
13030
Hello, Tom -
You may find this instructional YouTube video helpful:
https://www.youtube.com/watch?v=qC8LN32ep_Q
How do I unclog a T-1060 Waste Disposer
TURN OFF POWER before sticking your hand in.!! But first check the reset button underneath the unit. Also, try to rotate the spinner with hex key usually provided.
How do I unclog the pipe under my garbage disposer?
I am not aware of any that have a pipe under them can you tell us more
1helpful
Garbage disposal is clogged
Does the other side of the sink drain? Are you sure it's the disposal thats plugged? If the disposal is plugged you can turn it on and plunge it a few times and see if that makes a difference.
Titan garbage disposal
Push reset button located bottom of disposal? Use broom stick and rotate stuck cutter disk?
Copy following link to troubleshoot by type of problem:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Titan appears to be repackaged sinkmaster garbage disposal.
There is no service manual or installation manual on brief web search. However link above has manuals sinkmaster and other brands .
Add a comment and say what you discover
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
Garbage disposal is jammed kitchen aide kwd-200a
Use broomstick:
Copy following link to repair, troubleshoot and replace disposal:
Add a comment as needed, or repost question with detail
Leaks frm bottom of disposal,is there a gasket or a seal inside or should i just replace the garbage disposal
Replace disposal
Our garbage disposal won't turn off. batch feed
Turn off circuit breaker, and replace switch
Top Garbage Disposals Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Garbage Disposal Expert? Answer questions, earn points and help others
