Question about La Crosse Measuring Tools & Sensors
Lacrossse outdoor sensor
After rainstorms my outdoor temp senders stopped sending
    Top Expert:
  • La Crosse Master
  • 51,932 Answers
Water infiltrated the transmitter
Posted on Dec 22, 2017
2 Suggested Answers
SOURCE:
  • 574 Answers
SOURCE: temp sender
If it's like my 98 cavalier it's located in the housing where the upper radiator goes into engine, it's right beside it.
Posted on Sep 06, 2009
Testimonial: "it was right there....thanks...got a mouth full of antifreeze but was able to fix my car. gonna go to school to be a wrencher now :)"
Water temp sensor on 2005 nissan titan
Here's a link to your coolant temp. sensor,you may have a coolant temp. sender too,they are by each other, Duralast Coolant Temperature Sensor SU4072 2005 Nissan Datsun Titan 2WD... Here's a part list. Part Detail There's no way to test it,just have to replace and see if it solves the problem.I have a 85 nissan 720,mine has both sensor and sender,the sender operates the gauge on dash,the sensor sends signal to the brain.
Jul 19, 2014 | 2005 Nissan Titan Crew
2.2L Chevy Cavalier- temp gauge always redline, fan kicks on as soon as car starts but the car is not overheating. Temp sensor? Temp sending unit? Something else? Help!
check the that wire to the temp sender unit is not shorting out as it will read hot if it is remove the wire and if the gauge goes back to cold then replace the sender unit.
Jan 05, 2014 | Cars & Trucks
I have a 2007 Chevrolet Equinox and had my cluster repaired for the temp gauge. Now it works but will not drop the entire way after it cools down. I was told that this is a temp problem with GM vehicles...
From what I just read about your vehicle,it has a history problem with the gauge,may be the coolant temperature sender or the gauge,it says the whole cluster will have to be changed to be fixed if the gauge is bad,found some forums and all had gauge problems.Right above the coolant temperature sensor is the coolant temperature sender,this is what sends the temperature to your gauge,the sensor sends a signal to the computer,they may have replaced the wrong one,here's a link to the sensor,the hole above it is where the sender goes,it's a one prong part,the sensor is a 2 prong part.A lot of people don't know that there are 2 types of coolant temperature gauge sending unit and sensor.
Nov 06, 2013 | 2007 Chevrolet Equinox LS New Cars
1990 Buick Century 3.3l V6
no, when the temp sender stops working or gives false readings, the pcm automatically assumes a fixed reading and sets a code. I would check for codes relating to map or maf sensors, or even intake air temp. It could be a bunch of stuff, you need to read codes first. if you got a lean mix code, it could be pump or regulator related.
Mar 25, 2013 | Cars & Trucks
Taylor 433MHZ cable free thermometer won't show outdoor temp
Check battery in outdoor sender and reset main unit to receive transmission of data. If nada could be that you have an issue either with the sending unit or the receiving unit of your weather station. Has happened to me a few times already so .................
Jan 22, 2013 | Measuring Tools & Sensors
WEATHER STATION AC100MB stops transmitting outdoor temp
I have experienced the same with numerous different, "quote un quote" atomic clocks! Please don't forget that this sender unit, that goes outside, generates a RF Singal to be received by the clock inside. This unit transmits a signal 433 MHz signal approximately every. 3 minutes, and after so many years the sender unit's RF section(electronics) just goes out or no longer function properly or not at all! The transmitter/sender for this model number, according to "3M" is obsolete and can no longer be furnished, DRATTS !!!!!
Mar 20, 2012 | 3M Measuring Tools & Sensors
I have an Audi A4 2.5 V6 TDI. starts lovely when cold but when warm it doesn't start so easy. So far I've changed the cranking sensor, Glow plugs & ECT sensor . . . Any suggestions?
can be injectors leaking when parts is warm and expanded or temp sender not sending correct signals to ecu,so get injectors tested and replace temp sender.hope u succeed.
May 27, 2011 | Audi A4 Cars & Trucks
My temp gauge is not working and since that,when the car is hot,it stops everywhere and it is hard to start,like it s flooded ( to much gas )is it the temp gauge the problem!
Hello francis.
If the temperature sensor is defective it will send a cold signal to the computer.
This cold signal will make the engine run rich (too much fuel).
Cold engines need more fuel to run so that is why it is rich when hot.
But...the computer has a separate sensor from the gauge sender.
Which engine is in your Pontiac? 2.2 or 2.4 ?
Let me know here and I will send you some location diagrams.
Dec 28, 2010 | 1999 Pontiac Sunfire
Measuring Tools & Sensors Logo
114 people viewed this question
Top La Crosse Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
