Exercise & Fitness Logo
Mark Strazynski Posted on Dec 22, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What's the difference between Precor M 9.2 and M 9.2s or 9.2X? I need to replace a drive motor for M 9.2 but all I see are motors for 9.2s or 9.2x.
Stephen Miller
Level 3:
  • Precor Master 1,645 Answers
  • Posted on Feb 25, 2019
Stephen Miller
Precor Master
Level 3:
Answers
1645
Questions
0
Helped
865491
Points
9471
Http://www.fixya.com/support/t26836570-difference_between_precor_m_9_2_m_9_2s
ebay and Amazon have these but I suggest you order directly from Precor.
5 Related Answers
Anonymous
  • Posted on Apr 24, 2009
SOURCE: 2002 Sebring LXi Convertible Starter Motor Fuse Blown 2x
Starter solenoid. I don't have the page here but in chiltons a page shows the ignition to fuse to relay to starter and if you look closely it's quite basic. I had same problem with constant fuse blow #8. The solenoid over time wears and sometimes sticks. When it sticks, your system can overload thus burn fuse. I bet you never stalled out while driving, but only when you shut off and start somewhere it's a no go. That's because you're system is already engaged. I had to change starter as solenoid part of it all. I see others suffer this same problem so please share this around. Solenoid can stick for a millisecond.
Anonymous
  • 11 Answers
  • Posted on Apr 27, 2009
SOURCE: can I add additional drives to Raid 1 in order to expand storage?
I am not familiar with the specific model, but my guess is you can setup another separate logical vlume by using a RAID1 for the new disks. You will not be able to add the disks to the existing volume.
If there is no data, and the array supports it you can delete the existing volume and setup a RAID 5 instead, which will use all 4 disks, as long as they have the same capacity.
Anonymous
  • Posted on Jul 12, 2009
SOURCE: Replacement electric motor for Bissell Pro Heat 2x Select carpet
bissell proheat i can spray solution from the handle but it has no suction help
Anonymous
  • 43501 Answers
  • Posted on Sep 30, 2010
SOURCE: I need a Bissell Proheat 2x assembly drawing
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
j
Anonymous
  • 3 Answers
  • Posted on Feb 08, 2011
SOURCE: BISSELL PROHEAT 2X 9200E - BRUSHES WON'T TURN
Hi there if u have already replaced the brush motor and the brushes stil aren't rotating, you wil need to also replace the circuit board that is located in the upper part of the machine after u take the 5 screws out the back, hope this helps, I repair bissells for a living so any problems email me, [email protected]
I am trying too use my Bissell Proheat 2X, but the brushes will not rotate. What is wrong?
1. Can you hear the electric motor in the base unit going?
2. You may have a broken drive belt.
Type the following link into your browser. It will bring up the user guide to the Model 9500p upright ProHeat 2x.
2helpful
Where can I find a Precor 9.21 treadmill motor cover?
Do you know which version of the Precor 9.21 you have? There are a few different versions you can view here. Click on your version to view the parts list and look for "Cover, Motor" or "Motor Cover".
For instance, if you have the 9.21 (AYYZ), the proper motor cover is this part #5019749
However, this part #5005569 is listed as the proper motor cover for the 9.21 (F5), 9.21i (2X), 9.21s (F6), 9.21si (2Y), and a couple others. Make sure you have matched up your exact model number with the motor cover you need so do you not order the wrong part.
My bissell proheat 2x wont vacuum up water
There is a float (usually looks like a red ball) that rises up if water is in danger of getting to the motor. Sometimes they stick.. Give it a poke to free it up.
All the best,
WD
Same here too!
heatman101
ar2
Roller brushes siop after a couple of seconds
heatman101
87uyf
Brush Motor Replacement
This the number for the brush roll motor, 2036757, is it the one you got? I don't remember having to remove the pulley, I am thinking that the pulley is on the new motor. The 8920 is a good number? Where you on the Bissell site, or some other site.
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
