SOURCE: no steam coming out and water tank not pumping water into generator to make steam
The Rowenta DG-980 Iron/Steam Generator works great from our experience (it is a consumer grade unit with commercial grade technology) and over 90% of the user reviews I have seen are happy with it, unfortunately it is a discontinued model & the newer replacement is not as good. Service seems to be rather thin, as is the case with most corporate entities; I was on the phone for 30 minutes before I was able to locate service center in Concord, CA (I am in SoCal), and is the only one in the state that does repairs on them, and I am going to check them out...stay tuned.
SOURCE: Tefal Pro Express Steam Generator doesn't.
OK... so I have fixed my problem of NO STEAM, just lots of water coming out of the iron press plate itself... I had already cleaned the boiler, so I tried adding 1/4 tsp - 1/2 tsp bicarbonate soda to the water and flushing it through. From what came out of the iron press plate, I would say the problem was caused by a build up of goop (technical term) inside the iron. Once cleared, the iron is steaming away again. Please note, u will need to have an old towel handy if this is ur problem, 'cos until it starts getting better, there is a fair amount of water coming out of the iron press plate. Just add the bicarb to the water reserve and use the steam buttons to bring the bicarb through. Do not attempt to iron clothing with the bicarb in the water!!! Carolyn ;)
SOURCE: my kenwood steam generator iron
Hi,my new steam generator didn't come with a manual and the filter button keeps flashing. The unit works fine but what's the flashing red light for? It's bothering me! lol
SOURCE: MY ROWENTA 1550W UPRIGHT STEAMER NO LONGER
I have a Rowenta garment steamer. It will turn on but no steam comes out. Does it need to be cleaned from the build up of iron, etc. from the water? If so, how do I go about this?
SOURCE: I have a Bosch Steam
Your steam generator my have mineral deposits that are clogging the steam openings. One of the easiest things to do is to pour out the water and add white vinegar. Let the vinegar sit for about 2 hours. Then turn on the iron and press the steam button until the deposits are loosened and flushed by the heat and steaming vinegar. Do this on a towel or other absorbent fabric so you don't stain your ironing board. You may need to unplug the iron, let it cool and then gently **** the steam vents with a wooden skewer or toothpick.
I hope this helps you. If it does, please rate my suggestion!
