Question about New Bright Motor Cycles Harley Davidson Mighty Bikes Battery Operated Fat Boy
How to remove the battery from a New Bright fat boy Harley Davidson remote controlled motorbike
SOURCE:
Pyrhyc
  • 2028 Answers
SOURCE: 1995 fat boy- harley davidson
This is going to be a problem that will need to be tracked down because there are several things that could cause this. It's going to be in the electrical system, and any one or combination of the following can cause this, Faulty switch, especially the ignition switch, bad wiring which could be a bad connection, loose ground, bare wire, or broken wire, These are the two cheapest, but the hardest to find. Now, it can also be a bad or malfunctioning ignition module, coil, voltage regulator, and magneto assembly. You will have to test each of these. I recommend that you start at the spark plug end and work your way back since most of this is in line and work in conjunction with each other. Keep in mind that this being an intermittent problem, it may be extremely hard to find.
I also have a 95 Softail, and recently had a similar intermittent problem, turned out that there was a hairline crack in the regulator, and the problem would only occur if the regulator was warm enough for the crack to open a bit. I also traced the wiring harness, found and replaced several wires that were in bad shape, thinned, stretched, corroded, etc... You will be amazed at how much wear the wiring harness will have on a 13 year old bike.
Don't let this discourage you. In my opinion, the mid to late 90's models are the best HD ever built, and the Evo is by far the best engine. With the newer bike you have to worry about things like, crank and cam sensors, ECM's, fuel injection, and all the other electronic BS. It's to the point that the average rider can't work on his/her own bike, which is getting away from the HD tradition. That's a great bike you have, keep it for a long time. I may buy a newer bike someday, I don't know, but I do know that I will always keep my 95. Good luck with this and be safe.
Posted on Sep 16, 2008
  • 22 Answers
SOURCE: oil come out the air cleaner
Too much crankcase pressure or the breather pipe is split/dosconnected. The crankcase breather goes into the rear of the air filter and the crankcase gasses are drawn in to the cylinder with the gas/air mixture and burned
Posted on Nov 10, 2008
  • 2712 Answers
Posted on Nov 20, 2008
Mitchy123
  • 216 Answers
SOURCE: correct torque for rear axle nut on 1997 harley davidson fat boy
Harley manual says 60-65 ft lbs... do NOT exceed this or wheel could seize
Posted on Apr 04, 2009
OneRide
  • 384 Answers
SOURCE: 2001 harley davidson fat boy fork seals leak
Either the seals were not installed correctly or your tubes and sliders are excessively worn. Not changing the fork oil at recommended intervals will cause excessive wear. Overfilling the forks will cause leaks too.
Posted on Jun 04, 2009
How do I put new battery in 2007 fat boy
Hi, Patricia for this scenario you will need your service/owners manual if you can not find the first and best tool you ever bought for your Harley, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
Need help replacing 06 fatboy battery Harley Davidson Forums
Motorcycle Repair How to Replace Battery on Harley Davidson Motorcycle
http://www.carlsalter.com/pdfs/Harley%20Davidson%20Softail%20Service%20Manual%202007.pdf
http://partsfinder.onlinemicrofiche.com/stcharlesharleydavidson/showmodel.asp?make=hdmc
https://serviceinfo.harley-davidson.com/sip/vehicle/lookupForm
How 6ya Works 6ya A must have !!! Totally "FREE"
Dec 04, 2016 | 2007 Harley Davidson FLSTF Softail Fat Boy
2006 Harley Davidson FLSTF Fat Boy alarm will not disarm
Hi, Tyler for this scenario you will need your service, parts fiche, and owners manual if you can not find the best tool you ever bought for your Harley, despair not, for a mere $8 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
How to Arm Disarm Factory Alarm
Harley Davidson Softail Workshop Service Repair Manual 2006 $8 http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://mybikemanuals.com/harley-davidson/2006-harley-davidson-owners-manuals
Instant Tech Relief To speak to me personally absolutely "FREE"
Mar 28, 2015 | 2006 Harley Davidson FLSTF Fat Boy
Replace battery on 07 FLSTTI fat boy
Hi Anonymous, for more information on your question please visit the websites below and good luck:
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 11, 2013 | 2001 Harley Davidson FLSTF - FLSTFI Fat...
Remove rear tire from frame, harley davidson fat boy 2004?
Hi Williethedri, for more information about your question please visit the websites below. Good luck and have nice day.
How To Remove Install Rear Wheel Harley Davidson Softail
Mar 21, 2012 | 2003 Harley Davidson FLSTF Fat boy
How do I access the battery on my 03 harley fat boy
Remove the seat. It's in the center fo the "horseshoe" oil tank.
Good Luck
Steve
May 13, 2011 | 2003 Harley Davidson FLSTF Fat boy
I am missing parts.
Sale me transmitter of HD
May 14, 2010 | Video Game Consoles & Games
I am missing parts.
search the manufacturer
Mar 25, 2010 | Toys
2001 fat boy battery
Its under the seat, all u have to do is remove the seat, remove the negative connection at the frame and the positive at the terminal, unlatch the battery strap and lift it out
Mar 22, 2009 | 2001 Harley Davidson FLSTF - FLSTFI Fat...
New Bright Motor Cycles Harley Davidson Mighty Bikes Battery Operated Fat Boy Logo
89 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
Jonah Oneal
gerry bissi
Are you a New Bright Toy Expert? Answer questions, earn points and help others
