Well looked after system, not abused in any way.
SOURCE: Teac GF-350 CD Shelf System
Firstly double check that the recordable discs you have bear the label "Digital Audio" on them as per the attached picture. Secondly what happens when you go through the finialise procedure in the manual? Do you see the ?FIn--d? display when you select the finialise button? Do you see ?NO TOC? and ?REC? indicators blinking at the next step? Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: Marantz CD-5000 CD player
see if the player tries to read the disc. Load a disc and listen.
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
If still ur problem is not solved then i am sad to say you have to get it repaired and thats the only solution..
Good luck..
SOURCE: CD player won't play disk and says "no disk"
The problem of "'no discs'"displayed is in the mechanism in the roller thats moving back and port bringing the lense set .The old grease thier is already hardened that cause the problem.Clean that by using a lighter fluid or like that fluid to take the old grease,and put it with a new one first class grease type-A grease put only a little grease and wipe the lense with a cotton buds without any chemicals on it .Try this solution so performance will be better.
SOURCE: Pioneer PD-F100 Constantly Skips to Next CD
the problem is not the laser, but the cable that connects the laser to cd board, it is cracked..and will break connection when moved out from its home position, i have replaced a lot of cabes for this model..i know it well
