If it is a Fluid master 400.This video should be helpful.
https://www.google.com/url?sa=t&source=web&rct=j&url=%23&ved=0ahUKEwiClPbOrMfYAhWD5IMKHZL2D6UQxa8BCCUwAA&usg=AOvVaw0VTJzWxrN8ZFOD4xbU2nov
SOURCE: toilet not flushing properly
there are allot holes around rime inside they get clogged over time because water quality very hard to get there to clean best bet replace toilet
SOURCE: Toilet Bowl Water Level Slowly Drops
Check the fill tube in your toilet one easy way to see if it's leaking is get food coloring and pour in your tank to color the water this makes it easier to see and squeeze the tube in the tank when it's full if you see the colored water running down the middle of it you have a winner! if not you can look around for it sometimes the plastic under the flapper gets cracked too
SOURCE: Toto flapper seems ok but toilet keeps slow trickle into the bowl
The water inlet valve should close completely and stop water from coming into the tank before the water level reaches the "small tube." (This is the overflow tube.)
There may be an o-ring or rubber gasket inside the valve that can be replaced. If not, you would have to replace the water inlet valve.
SOURCE: I have Jacuzzi toilet (one
Somthing is leaking. Find it. Sometime you have to use a dye. but look at everyghing obvious.
