SOURCE: find board for maax bubble-tub
You will probably have to go to the manufacture website to find a dealer in your area that you can purchase one from. Also, you can check online as well for specific parts for your tub. If often just google the brand and model number and start clicking on links to find what I want or need. Good luck to you!
SOURCE: Cold air blowing into Maax Velvet 6032 Bubble Tub
The air coming from the blower will be cool, but should not be cold. Turn on the blower or bubbler feature (no water necessary) and go to the access panel ( as specified by install instructions), reach in and feel the tube connected to the blower, the tube should be warm, if not the heater coil is not working and the blower assembly needs to be replaced.
SOURCE: Maax Spa Question
They should have an online manual of the website. Look that up or call costumer service
SOURCE: Maax tub LM65519 control panel has broken lines running through
Broken lines where? are you referring to broken water lines or the actual control line?
rod
us parts center
