PF is power failure error meaning electricity has been interrupted to the machine. An electrical interruption of any type can cause a PF error code. Try this: Press the Pause/Cancel/Stop button twice to clear the PF in the display.
Red wire to the positive voltage. Black lead to the negative voltage. Almost every car these days is negative ground.
Some vehicles have a spare pin on the fuse blocks that you can connect to. However, you can get FUSE TAPS on line for a couple of bucks that will allow you to tap into a fuse position so you can power external things.
Hi there, im assuming you have the ARF 2001 scanning/transceiver. I found your print and C4 is 1000 and C5 is 1000. Example: capacitor 101, it is measuerd at micro (uf) and picofrads (pf) therefor this is calculated at 0.001 (uf), 1000 (pf). The answer to your question is capacitor code for C4 & C5 is 1000. 0.0001 (uf) or 1000 (pf). I hope this helps.
