Yours is a CONAIR WW11R and your manual is found here:
https://www.conair.com/assets/files/WW11R-Scales-Instructions-Booklet.PDF
But sorry, I found no info in it about 'calibration'.
Also found at this FIXYA 2009 Link :
"I replaced the battery, but still got the same message. My wife noticed that one of the feet on the bottom of the scale was loose. The feet are twisted on to the scale and held by two small flanges. When I gently pulled the loose foot away I noticed that a small black wire had broke. I used my fingernails to remove a small bit of the wiring cover and twisted the ends back together. I then hide the wires back in a recessed area on the foot and placed it back on the scale. Worked just like the day I got it. Hope this helps!
WW11r scale ERROR
ANTHONY
SOURCE: metric instead of pounds
You didn't mention brand name or model number, so not sure about your specific case. However, on my scale, there is a switch or button near the battery compartment. It allows you to change the measurement between stones, pounds and kilograms.
SOURCE: Scales showing Lo after battery has been replaced
Anytime you have trouble with a Taylor scale - they have a lifetime replacement warranty. You need to call their 800 number and pay for 1 way shipping and they will send you a new one.
SOURCE: how many grams is in one pound? i have only a
there are 1000 grams to a kilogram,and roughly 2.2 lbs to a kilo. so mesure roughly 1/10 of of 2.2 lbs which is .22 lbs or a quarter pound hope that helps
SOURCE: My scale resets to zero but then doesn't show the
A foot probably loosened up as mine did. Contact with company resulted in this:
Thank you for contacting Health-o-Meter, a brand of Jarden Consumer Solutions. We apologize for any inconvenience you have experienced with your scale and will be happy to help you.
Unfortunately, the part you are inquiring about is not a replaceable part. Again, I apologize for any inconvenience.
We appreciate your business and are happy to help if you have any further questions.
Sincerely,
Leslie
www.healthometer.com
We are interested in your feedback regarding your email experience. Please click the link below to complete our online customer satisfaction survey. You will need to enter in or copy/paste the following reference number. 1-906692191
http://research.affina.com/snaponline/surveylogin.asp?k=128864872801
SOURCE: when set on lb,pounds, scale
Hi dogwalk564,
Make sure of the following:
Be sure to place the luggage in the dead center of the scale, this will distribute weight evenly across the scale, also try to keep it on a level floor, any slight incline or decline to a side of the scale, will give you a bad reading.
How do you know the scale is incorrect, how do you reference it to the current reading?
Kind Regards
JEDMEEYER1
* If this solution helped, please accept it
