Are your RCA headphones wired, IR, FM wireless, or do you mean they have RCA/phono plugs?
Whatever the config, you'll need a DAC,or digital-to-analog converter for a start, as the fiber-optic transmits a digital-encoded pulsed signal only, which has to be decoded back to the audio sampled voltages to re-create the original wave-shape.
The DAC must have D/A optic input.
SOURCE: LCD HDTV digital audio output jack
The orange jack is a DIGITAL audio out and cannot be hooked to anything other than a digital input. You want to use the White/Red jacks at the bottom.
SOURCE: Computer to Denon via Monster Headphone cable to V.Aux (Front) RCA inputs
Are you using a stereo-mini to RCA cable that has a red and a white RCA plug? What I mean is, you should have the one cable coming out of the headphone jack on the computer, and two (left and right) cables going to the receiver. The only other thing I can suggest is making sure the cables are tight. Maybe try another input on the receiver. There really shouldn't be any feedback unless there is some underlying problem.
SOURCE: HDMI AUDIO NOT PASSING THROUGH?
OK try to connect all to tv and from tv connect the sound in digital to H/K receiver and you will have sound at the receiver no matter what.
SOURCE: Trying to connect digital audio output optical terminal to existing analalogue hi-fi amplifier
there should be on the tv out a red and white rca output or a coaxial, your yamaha my be too old to deal with the outputs on the tv. at the jvc website you can download the manual for this tv.
SOURCE: Digital optical from DVD player produces no audio
Hi, It sounds like your receiver is still looking for audio on the coaxial connection, rather than the optical.
1. Make sure the optical connection is between your DVD player and the LD/DVD Optical In on the back of your receiver.
2. If you have a monitor connected to the receiver to show the on-screen display, click Setup from the main menu, click Input Mode, then, next to LD/DVD choose Optical. It may be set to coaxial, analog or auto.
Alternatively, choose the input source on the front of your receiver (LD/DVD), then press Input Mode button (bottom right, near the input selector) till it displays Digital Optical.
If all else fails, reset the receiver by:
1. Turn off the receiver
2. Hold down DISPLAY and PANEL UP/DOWN buttons and press power.
3. All Clear should appear on the screen.
Use caution, however, as this will erase all the settings in your receiver.
