SOURCE: subwoofer
Yes you do as this is were it gets the information from to play a bass line or effects from a film,if you dont have a amp or receiver you have a coffe table.
hope this helps.
CABLE GUY.
SOURCE: how to connect pioneer reviever to velodyne subwoofer
Look for the sub pre out on the back of your amp and connect a sub cable to this and next to the LFE or phono type input on the back of the sub ,if it has two inputs left and right pick the left side ,set the cross over to suit your system and speakers,if you are not sure set the cross over to 80 hertz,this is a thx standard.
hope this helps.
CABLE GUY.
SOURCE: My Velodyne DPS-10 subwoofer hums when you plug in
hi,
You have to check the RCA cable to the sub woofer. The RCA cabe have two connections inside it, one is for gain and the other is for ground sheild. If the ground sheild is broken then there will be hum from the sub woofer and it will increase if you touch the ground (rear metal pannel is connected to the ground). Replace the cable and check it again.
ok
