Question about York Fitness Z16 Treadmill
How to fix error E2 on a York Z16 treadmill please
The platform does not go up and error E2 is on screen thank you
How do you replace a cracked running deck on a York Z16 treadmill ?
If you wish to get some details; check the site linked here. Pull up older posts.,,
http://electro-medical.blogspot.com/
Jul 24, 2016 | York Exercise & Fitness
Where to buy replacement fuses for z16
Often these devices use the same style fuses ("blade style") as modern cars. YOu may find what you need at the automotive section of WalMart.
Apr 23, 2014 | York Fitness Z16 Treadmill
My Exerpeutic TF1000 treadmill shows a E2 error, motor will not start.
see this steps and fix it.God bless you
This is probably a 1( faulty speed sensor, adjust it , clean it and tigh the plug very well see the diagram attached. 2( test the input voltage motor, if there are the motor need repair 3( test the output voltage board, for input voltage motor, if there are NOT the board is faulty see the block diagram . The error codes will differ between makes and models but could be e1. or e2
Run the software calibration for easy diagnostic, troubleshooting, and fix it.
God bless you
Oct 01, 2012 | Ironman Exerpeutic TF1000 Walk to Fitness...
E2 Code on Treadmill after starting
This is a speed sensor error. Unplug the unit then remove the motor shroud locate the power board with LED lights plug in unit locate the 5v DC if this is on then replace the speed sensor.The sensor is located on the frame by the front roller pulley or on the Drive Motor itself. Call IconFitness @ 1800-999-3756.
Jun 26, 2010 | York Barbell Home Use Fold-Up Treadmill
I have a v-fit kik-036-11 and keep getting e-1
Your problem might be a magnet that has fallen off from within the treadmill. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Jun 02, 2010 | Exercise & Fitness
The treadmill starts then after a few seconds it stops and a code L5 or LS comes up. the model is a york fitness z16
More likely LS= Loss Signal open the motor shroud on the motor their should be a cylindrical shape sensor (magnetic). Plug in treadmill and on the motor control board their should be a L E D (red or amber) by manually rotating the motor you should see that light flicker if it does sensor is good if not replace sensor. Next thing if sensor is good check motor brushes to see if they are mis-align or worn if worn less than 3/8" in length replace them
Mar 09, 2010 | Exercise & Fitness
I have a error reading of l5 or ls not too sure york fitness z16
The L5 message means that there is a problem with the speed setting switches. Some models have one set of speed adjusting stitches on the handlebar and another set on the console. One of them is defective and is causing the problem.
Dec 29, 2009 | York Exercise & Fitness
Ls error
Showing l5 or ls on sceen of my york t101 treadmill please help me out thanks.
May 09, 2009 | Exercise & Fitness
York t500 treadmill model no:LQ6010 showing err07 when turned on
Error 7 is a Safety Key Error..
that's the red magnetic circular thingy on the console.
Simply secure the safety key in place and try it again
Jan 19, 2009 | York Barbell Home Use Fold-Up Treadmill
York Fitness Z16 Treadmill Logo
79 people viewed this question
Top York Fitness Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Tom Chichester
ray gallant
ray gallant
Are you a York Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
