It was unplugged for several hours. Still comes on with the AE error code. I tried the drain and cancel, child lock, still showing AE code
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
SOURCE: Have a kitchenaid dishwasher KUDS25SHWH1 - the
Unplug the unit for 15 minutes then plug it back in. This should reset all your computer system and make everything work again
SOURCE: How do you get the child lock off?
Please find complete process to switch off the child lock.
http://www.ehow.com/how_5144877_turn-kitchenaid-dishwasher-child-lock.html
Most of the dishwashers are same so the model should not be a problem
Thanks
SOURCE: The dishwasher won't start, its stuck, pots/pan
did you hold the start/resume button for at least 3 seconds if this works the dishwasher will start ok but if there is a fault it will fail again best you contact your nearest service agent good luck
