Question about Sony Office Equipment & Supplies
Sony CX-355 changer - Service Manual, p. 22 Alignment Procedure - step 8 gives "Error 7 BR related 7 Auto focus adjustment cannot be performed. How do I fix?
SOURCE:
  • 1694 Answers
SOURCE: Perfect Focus 2
Use a site like servicemanuals.com and get the service literature for your make/model.Do NOT perform factory reset procedure-that is reserved for when certain parts are changed.You will need the access sequence,adjust info and add to memory step for servicer convergence.Keep in mind--you may have defective convergence IC's.If so,you will have difficulty w/alignment.Use OEM or better IC's no generics!! They won't hold up.
Posted on Sep 28, 2007
  • 11 Answers
SOURCE: computer shows no display
did you try installing newest drivers from intel/gigabyte website? what you described looks to me as a overheating problem. try running the game with case open. are you running on the integrated GMA graphics or PCI-E graphics card(like geforce, radeon)?
Posted on Jul 02, 2009
  • 41 Answers
SOURCE: lost my owner
If your interested in purchasing another owners manual just GOOGLE the model and put owners manual after the model number,(cdp-cx 355 owners manual) it will give you many web sites that you can purchase one from.
Posted on Nov 06, 2009
SOURCE: Needs cleaning and adjusting, esp. auto-focus which is eratic
when pics are downloaded onto computer, they come out very blue-coloured
Posted on Dec 26, 2009
  • 23 Answers
SOURCE: Unit Powers Up OK -
This projector has a very short throw distance of approx. 7 1/2 feet to 9 1/2 feet. Anything over or under that distance will be out of focus.
Posted on Jan 14, 2011
The battery got disconected now windows dont work tried re program checked fuses nothing now what
You need to do a window reset. Its in your owners manual
This is a quote from the workshop manual
Note
? A driver side window will not fully close automatically under following the conditions:
? The battery has been disconnected during vehicle maintenance or for other reasons.
? The power window main switch connector, or driver-side power window motor connector has been
disconnected.
? Carry out the following procedure to resume operation:
1. Turn the ignition switch to the ON position.
2. Press the driver side power window main switch and fully open the driver side window.
3. Pull up the driver side power window main switch to manual-up position to fully close the driver side window,
and keep holding the switch up at the position for about 2 seconds to complete initial setting.
TWO-STEP DOWN FUNCTION OPERATIVE/NON-OPERATIVE SWITCHING PROCEDURE
Note
? By following the procedure below, the two-step down function is switched to non-operative when it is
operative, and to operative when it is non-operative.
Turn the Ignition on
Within 5 sec
perform the auto open two times
perform the auto close two times
turn the ignition off and within 40 seconds and repeat the above sequence.
Repeat for all the windows.
Aug 14, 2016 | 2007 Mazda 6 2.3
I need a wiring diagram on how to configure a new harness for my panasonic DP 801 8 DISC CD CHANGER....MODEL CX-DP 801 EN
All parts and service manuals can be obtained by calling the Panasonic National Parts Center directly at 1-800-332-5368 9am-8pm EST during weekdays.
Aug 04, 2013 | Panasonic CX-DP801 8-Disc CD Changer
Service call error 00010040
Common Error Codes
00000101 The CR Motor reached it's end of life. 00010000 PF Encoder Check Error. 00010005 CR Motor is out of step. 00010014 Pressurising failure. 00010027 Pressure pump micro air-leak error. 00010040 Printing position error. 0001002D The cleaning unit reached it's end of life. 0001003F The Pressure Motor reached it's end of life.
Servicing Levels
Three levels of servicing are available and detailed below:
  1. Basic 0040 or 0001002D maintenance procedure: This will return your printer from either the 0040 or 0001002D error to a working state by replacing only the relevant maintenance items.
  2. Advanced 0040 / 0001002D maintenance procedure: As well as replacing the parts relating to the maintenance error additional adjustments such as bidirectional/unidirectional alignment, 980mm feed adjustment, firmware updating and a general clean will be performed.
  3. Overhaul: All maintenance items as well as the PF, CR motor and belt, cutter cap, pressure assembly and cutter solenoid will be replaced. A check for any design defects such as a defective cutter cap and a defective pressure lever will be performed and any parts will be replaced if necessary. All head and feed alignments will be performed as well as any required software updates and sensor verifications. A thorough clean will also be performed on the carriage area and the print head. When the procedures are complete a survey will be performed to better understand your requirements and any recommendations will be brought forward.
info.gifIt is recommended that if you have recently come into ownership of a second user Epson Stylus Pro 9800 then you should assume that the counter values or service life levels are incorrect and choose the most thorough procedure detailed above. The reason for this is an increasing number of printers being "reset" without the actual parts being replaced or inexperienced owners trying to repair or replace parts incorrectly. In one such case a part was removed and replaced incorrectly causing a serious ink leak which was luckily caught early due to the undertaking of an thorough maintenance procedure, but unfortunately extensive damage had already been caused to the chassis and maintenance tank area.
I copied the error code and put it in the search bar in a web browser and came up with the answer. In the future just google the codes and see what comes up. Also you can download a Field Repair Guide PDF and a Manual PDF from Epson's website too.
Jan 25, 2013 | Epson Stylus Pro 9800 InkJet Printer
Lost my owner''s manual for a sony cdp-cx 355 c.d. player
You can find electrical version in Sony oficial page. for yourn model HERE.
Nov 06, 2009 | Coffee Makers & Espresso Machines
Auto head alignment
#1 of 2
Carryout a Manual Print Head Alignment If Possible.
If the results of Automatic Print Head Alignment are not satisfactory, follow the procedure below to perform Manual Print
Head Alignment.
1 Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Cassette.
Important. You cannot print the print head alignment pattern if paper of size other than A4 or Letter is loaded. Be sure to use A4 or Letter-sized plain paper.
2 Open the Paper Output Tray, and then open the Output Tray Extension.
(1) Put your finger in the rounded indent of the Paper Output Tray and open it gently.
(2) Open the Output Tray Extension.
3 Press the Paper Feed Switch to select the paper source where you have loaded paper.
4 Select Settings on the HOME screen.
5 Select Maintenance, then press the OK button.
The Maintenance screen is displayed.
6 Select Manual head align, then press the OK button.
The confirmation screen is displayed.
Note. If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
7 Select Yes, then press the OK button.
8 When the Print Head alignment pattern is printed, select Yes, then press the OK button.
9 Look at the printout. From the patterns, select the most even, least irregular patterns for each column and input their numbers. Press the OK button.
(1) Select a column to input the pattern number.
(2) Use the or button to input the number of the pattern.
(3) Repeat the steps (1) and (2) until you finish inputting all pattern numbers, press the OK button.
Oct 08, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Red out of focus
Hi. your convergence board is failing. this board regulates the the alignment procedure and , the chip set is damaged. replace the convergence board soon.
May 22, 2009 | Toshiba 42H81 42" Rear Projection...
Perfect Focus 2
Sep 27, 2007 | Samsung HCN5527W 55" Rear Projection...
Perfect Focus
Perfect "FOCUS" is a misnomer.Convergence is the real issue.Enter servicer mode--perform accurate convergence alignment procedure--activate perfect focus as last step to 100% alignment.If you have a High-Definition source,check procedure for that.
43 people viewed this question
Top Sony Office Equipment & Supplies Experts
Jaime Hernandez
jasbo
jasbo
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
