There are chemicals on the market such as Round Up Or Weed Be Gone. or others that you can use to completely kill this weed. I have used Weed Be Gone and it does not kill the grass. Whether it kills this weed you would have to see. If you use Round Up it kills every thing even grass. I have sprayed a large area then replanted grass after the weed is gone.
SOURCE: How much roundup do I use in a gallon of water to get a good kill
This will be hard to answer because roundup is sold in different strengths. On a dry morning mix a few ounces of round up to a gallon of water and test it by spaying it on some blades of grass. Results should be noticed after a few days.If you spent allot of money for just a little roundup then you probably have a strong solution. Some roundup is already mixed with water (diluted) and can be applied as is. I hope this helps
SOURCE: son used roundup in backyard to kill weeds.
round up i think has a two week withholding period, so wait two weeks & turn the soil over & re seed is the only way I can see
SOURCE: Danger of roundup applications around tree and bush plantings
Hi , I would be very carefull around good plants. Roundup will kill almost any plant, including aquatic plants, so you want to be sure to avoid spray drift onto other plants or into water.
SOURCE: Agriculture Application of Round-up
Very important to buffer the pH of the water at pH 5. Then add Roundup /Glyphosate 360 at a 2% for grass weeds and 3% for brush weeds. Ensure that the grass is dry when treating and no rain is expected within 6 hours. Please take care with roundup as it is poison .
SOURCE: how much roundup concerntrated herbicide
for roundup weed & grass killer concentrate plus you would use 3 oz per gallon or 29.57 cm^3 per litre
Thankyou Dan ...we will give it a go I also saw a video on a herbicide called Dicamba that is used on this weed so we have a couple of options ......thanks again .....June Frew
