My Pioneer VSX-918V-K Standby LED Flashes. When I press the power button, the receiver will not come on (display is blank). I have tried unplugging it for a long time, but when I plug it back in, it is still stuck in that state.
Any help is greatly appreciated.
Thank you.
Hello there
Did you solve the Problem? I also have VSX-981V and StandBy flashes.
Do not know what to do!
Help is aprechiated
Testimonial: "With the power off try holding Tune + and Auto surround/stream direct buttons for a few seconds to reset the protection circuits. If that does not work try resetting the unit to factory defaults."
Unplug it and press the power buton and then hold the power button, and while your holding the power button, plug it back in
hope it worked!!!
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
My Pioneer VSX-D512-s LED Flashes. When I press the power butto not on
