SOURCE: amp works but no sound from sub
Some older Pioneer radios require you to connect the Subwoofer RCA to the rear output on the back of the radio and then you have to turn on the subwoofer in the menu on the radio. What model Pioneer radio is it? Also, make sure that the RCA plugged into the amp is on the input side, not the output side.
SOURCE: Blown crossover in a Peavey
Yes it can be repaired. Your best bet is to locate an authorized Peavey service center and order the crossover from there. Most will sell the replacement crossover directly. The cost of the individual parts will not be significantly less than the entire module. Are you sure that it is the crossover that is smoked? It is unusual for the crossovers to go bad. What is the symtom of the speaker failure?
Dan
SOURCE: magnet fell off speaker
Thats crazy well you could put it back on but how would you know that the magnet is perfectly centered so that the voice coil doesnt rub against it? How could you make it bond with the frame so that it doesnt come off again? HMMMMMM-cant take it back to the shop where you got it and exchange it? If it were me and i had no other choice-Id get some "liquid metal" and center it as well as i could and just epoxy that ****** right back to the frame unless i knew somebody who could tack weld it -Im not that lucky though so yup try some epoxy or liquid metal or some sort of super strong adhesive
SOURCE: I am trying to connect my infinity kappa series 52
THe amplifier connects to the crossover.. If you are using an amplifier there is no reason to connect the radio/deck to the crossover.
SOURCE: fried electronics in KLH ASW10-120B subwoofer
It is a 4 ohm nominal impedance woofer. If you put a new woofer in, it will last maybe half an hour and then fry/melt. The problem is the amp, not the woofer. Throw the amp out and use the box as a passive sub. Get a 100 hz sub crossover.
