SOURCE: Amana PTAC
Sounds like if this is a heat pump, maybe it tripped out on high pressure. Maybe just unplugging the system may reset the control boards. This maybe due to a dirty filter or dirty evaporator coil.
SOURCE: 2002 saturn heater
The problem is the blower motor speed control resistor, it is located near the blower motor in the housing.
SOURCE: Amana PTAC PTC093A35AA won't blow heat
The reset button is located behing a panel on the front of the unit that is labeled Heat Reset. If that label is gone then look around, it is a small hole, small enough for a paper clip to fit through.
That being said, I have 137 of these units in one of my hotels and have not had a single one needing to be reset. You probably are going to need a new control board kit. These can be purchased from Amana. They are $130. Make sure that you have pulled the heater coil out and inspected it first. Also, there was a recall years ago where Amana was supposed to contact and send out new voltage switches. These are the round black things that the Brown heater wires connect to on the upper and lower side of the heating coil. You should also try to replace those if you find the coil in good condition. I have had those resolve heating issues. Most of the heating issues were a result of a bad relay on the control board though.
Please remember to rate this fix.
SOURCE: fan doesn't work on low speeds in 2001 Grand Am
blower motor resistor is a highly probable cause.. another would be the switch/selector itself.
SOURCE: I'm not getting heat from my unit..
the compressor is controled seperately from the fan, this is done with the thermostat, try turning the thermostat on then of or untill you hear the "click" sound from the thermostat. If the compressor is still not turning on this may be more than you can fix if your not familiar with electrical hvac troubleshoting... more than lilkely the thermostat may be bad, or your compressors starting components are failing...if the compressor is comming on when the unit is turned on you could have a freon leak causing no heat. hope this may help some there is just too much to write on the causes this will give you a start though!!
