SOURCE: operating instructions for a replica Rolex
I need to know if this watch is an automatic or quartz (battery-operated) watch. For either watch, your crown screws in clockwise- which, by the way, is on the right hand side of your watch, and looks like a miniature doorknob. Unscrew it COUNTERCLOCKWISE, then, if your watch has a date on the dial (face of watch), your crown will pull out in two different positions. The first position is for your day/date. Forward will either do the day or date and backwards will do the other. DO NOT SET YOUR WATCH BETWEEN 10 O'CLOCK AND 2 O'CLOCK, because it can ruin your watch. The second position (pull out completely) is for setting the time. Go around until the day and date changes so you're sure that you're on a.m. or p.m. and then set accordingly. Push the stem all the way back in - this is your winding mode if you have an automatic. Wind 50 times before use, or else it won't run correctly. Now, push the stem back in (it's spring-loaded), and turn it counterclockwise to seat the tap, then clockwise until it's completely screwed in.
SOURCE: I can not open rolex bracelet
Sometimes Rolex bracelet clasps are very tight and this only shows the quality of the watch.
Don't be afraid to pull the clasp hard enough to open it- nothing will brake as Rolex is designed for quite hard use.
If you can't do it by hand, try to use flat butter knife end as a lever.
SOURCE: Rolex oyster perpetual datejust time/date setting instructions
Unscrew the crown pull out the crown to the first position, One click and rotate the crown clockwise. This is for Quick Set models
For non quickset
Depending on how old the watch is, It may be quick set or older models are not quick set. In older models you need to unscrew the crown, pull out the crown and rotate the crown to set the time, and in order to set the date rotate the hour hand past 12 twice in order for the date to change. Set the date first and then set the hour and min. For quick set models unscrew the crown and pull it out to the fist click this position you can "quickly" set the date by rotating the crown. Set the date and then pull out the crown to the second position out. Rotate the crown to set the hour and min. Then push the crown back in and screw it down.
SOURCE: how to adjust day date on older rolex perpetual day date watch
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex Day-Date is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in day and date setting position (depending wich way you turn the crown).
NOTE: to adjust the day or date, previously you have to advance hands forward, passing 12 o'clock (midnight) mark and stop advancing at 4.00 a.m. using the crown in position as described in chapter 3. When done - push the crown fully in, then pull out to the first click and only then adjust the day or date.
3) when you pull the crown further out to the second click, it is in time setting position.
To
find the daytime or night time on the watch: pull out crown to the
second click and advance watch hands forward till you pass the 12 mark
on dial. If the date changes as you pass it - it is the night time
(midnight). If the date do not change as you pass it - it is the
daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
