SOURCE: Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
SOURCE: What do I look for? Rangemaster Kitchener 110
Problem solved, took the back off the inside of oven and the element had a huge burn hole in it. Brought a new element from the local spares shop £17+vat. Easy to fit and it works better than ever.
