This also will fix the light not coming on when you press the Schlage button.
SOURCE: 2004 toyota sienna sliding door locking trouble
Sounds like something isn't right.Try to disconnect the battery for a few minutes and see if that helps.Some times the ecu gets haywired and disconnecting the battery might reset it.And if it is the original battery you might want to get it tested.
SOURCE: want to reprogam keyless lock
Turn knob once. Put in present combination. Open screw on the top, Use a small rod or drillbit that will fit into the hole. Press straight down on a lever that is inside of the hole,until it clicks. Turn knob completely(once) to clear old combination. Put new combination in, making sure that a click is heard upon pressing each button. Try knob with both the old and the new combination. Each digit may be used only one time in the combination.
SOURCE: need info to change code
Here's a link to the Schlage web site with pdf's and videos showing how to operate and program your lockset.
Just select which info you need from the list on the page.
http://consumer.schlage.com/customerservice/FE575_install_inst.asp
Hope you find this Very Helpful - Best regards!
look on the sticker located inside the outer panelo on the lock. you are going to need to disassemble the unit but it is in there.
