There are multiple HDMI inputs.
2 HDMI (side and bottom)
3 4K HDMI with HDCP 2.2 on the rear
Try connecting your Bluray player to the side or bottom input.
Here is a link to the specs
https://www.panasonic.com/uk/consumer/televisions/4KTV/tx-40cx680b.specs.html
Thanks, tried but had no luck. Also I could only see 2 hdmi on rear and 1 hdmi in the side
So do you see the bluray menu screen before you play the Disc? If so,
Maybe check the player video output setting try starting at 720p
If you can see the menu, then for some reason the tv is not accepting the content protection flag in the data stream.
If you see green when playing a protected disc then the display is blocking.
You are not splitting the signal to an amp are you? If so connect only the tv
SOURCE: problems connecting onkyo and panasonic blu-ray
hi look at these two posts
First
second
hope that helps
