I recently bought this used offline it was still new but not with the box i recieved it and go to install and it says it need an activation code is there a way to get this code or a way to bypass it
SOURCE: BOUGHT USED CAR WITH KENWOOD
go to a car audio place they might fix for you as kenwood site has no file on that item try straithfeild car radio or jb
SOURCE: recieving hy defintion picture
You need to do the following:
1: use HDMI cable to connect Cable box to TV
2: Call Cable company to activate HD service
3: Enjoy!
You can use component input, but the HDMI is best HD quality!
I hope this helps! please rate highly!
SOURCE: Windows Xp activation
If you don't enter the product key within a certain period after installing, Windows XP will expire, and will cease to function .
Check this out. If this does not help, then call microsoft , they will do it for you.You'll have to activate Windows XP again. However, since all your hardware is the same, Microsoft will simply re-issue you the same key.
http://support.microsoft.com/kb/307890
SOURCE: I recently bought a used whistler pro 73. The unit
Perform a factory reset (hold the power and quiet buttons in, while hold in these buttons plug in the power cord. Unit should beep twice) and see if this corrects it. If not contact Whistler at 800-531-0004.
SOURCE: have hp pavilion dv 2000 laptop. bought used.
that key is very important. try to read the key. because its a genuine operating system key. so it requires key
