SOURCE: Rowenta Steam Iron Leak
I have purchased two Rowenta irons. Both have the problem with water leakage. The entire iron looses all of it's water....both in the stand up position and the sitting down position. This happened after a couple of months for both items. I contacted Rowenta and they never responded. I will never purchase another item from them. Obviously, the irons must be defective. I'm going to contact consumer affairs.
SOURCE: I have a Rowenta 1700
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
SOURCE: Iron spits out rusty water. The iron is a Rowenta
Fill it with a mix of 50% white vinegar and 50% water. Let it set for 30 minutes and steam it out for about 2 minutes. Unplug it and dump it. After it cools colpletely, fill it with water and steam it out. The rust is coming from your water supply, not the iron.
SOURCE: I have a rowenta advancer DZ9080 iron that the
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
SOURCE: rowenta d1700 red flashes and iron shuts off
I am on my 3rd or 4th Rowenta. I recently bought the Rowenta Effective, Model DX 1700. Once again, I am having the same problem as before, it shuts off after about 30 seconds. From what I am reading, many people are having the same problem. I'm going to have to guess, this is a product defect. Do I contact the company for a refund????
