After the installation of the printer, users cannot print documents unless they are configuring the printer in a right manner. The configuration of printer requires especial skills and other technical knowledge that can be solved only by certified technicians. The configuration process is further done via computers or laptops to acceptably connect printers with the system and other networks like Wi-Fi etc. So, people needed any kind of online assistance for printer configuration process, can simply call us at our Toll-free Samsung Printer Support Phone Number 1-************ and get instant online tech support assistance.
SOURCE: How to configure printer on wireless network
On the computer with the printer hooked up to it:
Start
Run
Type 'cmd'
Type 'ipconfig' in the command prompt that appears
Take note of the 'IP Address'
Close this window out
Start
Control Panel
Printers and Faxes
Right Click the printer you want to share
Sharing
Sharing Tab
Bubble in Share this printer
Take note of the printer name
Hit OK
On the computer that you want the printer to work on, that is another place on the network:
Start
Control Panel
Printers and Faxes
Add a Printer, Next
A Network Printer, Next
Bubble in 'connect to this printer'
In the 'Name' field, type in \\xxx.xxx.x.xxx\printer name
---Where the X's are the IP address from the original computer and the printer name is the shared name that took note of when sharing the printer on the computer that it is directly hooked up to. Do not forget the backslashes. More than likely, it'll look like: \\192.168.1.100\HPPhoto or something along those lines.
Click Next
Decide if you want that printer to be the default printer or not, Next
And that's it.
Try to print a test page.
