I recently realized that my old flat screen had a VGA Port and a HDMI port on the back of it. Bingo! Long story short, I took an old 3.0GhZ, Win 7 Pro PC out of the closet, hooked it up to the TV with a VGA monitor cable, wireless keyboard and mouse, decent powered PC speakers, and BAM. Works great. NetFlix, YouTube, Hulu, whatever. Streams great. Not to mention PC games! Best thing I ever did with an old PC. It's just on a basic $49.95 a month Comcast router. Also, the TV has a good Digital Broadcast antenna attached to it (CBS,NBC,ABC,etc.). Just got rid of DirecTV! We watch WHATEVER WE WANT now!
SOURCE: netflix problems
maybe this can help. If not, please supply your TV model.
You need to register with Netflix online first to create a login and password.
Here`s how to:
>> On your computer go to netflix.com then click signup or signup.netflix.com
>> Fill all the necessary information they needed.
>> Purchase any plan they offer after you created an account(Optional as you can avail a trial version for 7 days)
Now go to your TV
>> Turn the TV on then hit menu
>> Go to My apps menu
>> Select Netflix
>> Sign in with your username and password
>> Take note of the code
>> Go to your computer and login to netflix.com/activate and type in the code to activate.
>> Go back to the TV select finish to start the service
Important:
Make sure your TV is connected to the internet, either wired or wireless
Here are the three methods to connect wireless on your TV:
Scan and connect
>> Turn on the TV
>> Go to Menu
>> Go to Network settings
>> Select easy then scan for networks
>> Select and connect
Connect using WPS
Press the WPS button(Padlock with signal wave) on your TV`s side panel then on your router.
Note:
You only have two minutes before the router turn the WPS off
Add network manually
>> Go to Menu
>> Select manually add network
Type and select the appropriate settings:
SSID: Name or the Wireless network
Security: Either the WEP, WPA, WPA2 or WPA+WPA2
Passphrase/Passkey: Type in the password
Wait for a prompt that the TV is connected to the internet.
Make sure that your "smart tv" is properly hooked up to your wi fi network. If properly connected and tv is working with other sites then contact Netflix directly and ask for their assistance with their application that is for what ever the reason just not working.
not sure if this will help you out,,,
Here's how to fix many Netflix streaming problems. Restart your iPhone, Smart TV, Game Console or whatever device you are using to stream Netflix. Restart your Router. Unplug your wireless router from power for 60 seconds then plug it back in.15 Oct 2015
14 Common Netflix Problems & Fixes - Gotta Be Mobile
https://www.gottabemobile.com/common-netflix-problems-fixes/..
or go to this link...
Netflix wont play Google Search
