Televison & Video Logo
Paul Machacek Posted on Dec 13, 2017
My Hitachi VM-H710A flashes Tape in the screen and It won't play,fast forward, rewind, etc. The manual says to clean heads but how do you do that? We can't watch home movies without it. Please help!
Peter Woodley
Level 1:
Habit-Forming:
New Friend:
  • Contributor 34 Answers
  • Posted on Dec 13, 2017
Peter Woodley
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
34
Questions
Helped
4699
Points
96
Go to tv/vcr/stereo service place and buy a Head Cleaning cassette.
5 Related Answers
Anonymous
  • 579 Answers
  • Posted on Jan 22, 2008
SOURCE: VHS tape was playing . After stoping does not play. Other tape will play
The idler wheel (that only drives the tape in play or scan modes) is slipping too much (very common problem). Try verify this by putting the tape in play then immediately press the fast fwd or rewind buttons to scan the tape. On older machines, the idlers used rubber friction tires - on newer ones, a clutch. Either replace the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
Anonymous
  • 71 Answers
  • Posted on Nov 24, 2008
SOURCE: Won`t Rewind
Do you still have the remote control? Try with the remote. If this works, the button of the camera is broken and have to be replace by a qualified technician. Good luck!
Anonymous
  • Posted on Jan 03, 2009
SOURCE: sylvania srd3900 error 2
Found no info in manual but cleaned tape heads and able to watch tapes. I don't know if this completely fixed problem because tape watched was not best quality.
Anonymous
  • 36 Answers
  • Posted on Feb 11, 2009
SOURCE: Sony GV-D1000 Powers on, will play memory stik, but not tape
C:31:23 error code means problem is in Supply Reel section.
If you are tech person you might got the point.
Unit has mechanical problem in supply reel area and reel pulse is not being generated as supply reel table may be stuck due to back tension.
Let me know if you need further help.
dsewizzrd2
harold
  • 8 Answers
  • Posted on Nov 26, 2013
SOURCE: rewind or fast forward
Try cleaning the pinch roller. A cotton bud dipped in methylated spirits should work, you may need several. Play a tape through to clean off the methanol residue. Avoid touching any semionductors !
If this doesn't work, you've just a tired motor.
My Hitachi VM H710A plays just fine, and the picture looks fine. But when it playsback footage or records footage, five to ten seconds later, it stops abruptly, and flashes the word "TAPE".
Try to rewind tape few times, also try on other tape if that happening to it? If that happens on every tape i would suspect loose belt somewhere in mechanism.
Put in tape and vcr fast forwards
something maybe broken on the inside for it to say play but fast forward. the botton could be stuck as well. maybe open the vcr and clean it all up in side. that might help
I have a Sherwood DS1150 tape Deck. Problem Cant open Cassette Door, tape is inside . Will not rewind or fast forward. Wont play. Any advise
Very likely the tape is wound around the capstan.
You may have to get at it by taking the unit's case off.
If I am right you might have to destroy the cassette unless you are very careful. Or, at least, have to cut the tape so as to unwind it from the capstan.
You could also try to open the door just enough to lift it up and off ... as if you were going to clean the tape heads.
Tape wont play back
Heads need cleaning, possible tension adjustment.
1helpful
2answers
Video tapes only paly for about 2 seconds then stops
The heads need cleaning and/or the tapes are old and dirtying up the playing heads.
Run a wet tape head cleaner through an see if this improves.
Sylvania srd3900 error 2
Tapes will not play
Video head is dirty / clogged. Use good quality Mini DV Head Cleaning cassette.
3helpful
4answers
VHS tape won't play or rewind
I work at the History Channel and have  a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
2answers
Incompatible Tape
try a cleaning tape first - best not to rewind the cleaning tape because it will put back the crud previously removed ? into your heads and guides ( last tape to play is prime suspect ) ; - - digital heads wear faster than analog so a new set of heads is next possibility but if the cleaning tape works . . . retire your library soon as possible .
Will not playback tapes
a sony cleaning cassette may clear the gunk from your friend ' s possibly ? bad tapes ( do not rewind it - or the gunk will be redeposited ) ; if still no video , get an estimate to have your heads and guides cleaned . . . professionally ;
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
