Question about Carrier Heating & Cooling
My Carrier Comfort zone 2 is flashing E1. I turn the unit off starts up then back to E1 again. Any answers? Very frustrating. Carrier don't want to help either!!
    Top Expert:
  • Carrier Master
  • 10,260 Answers
Thermostat not seeing ac unit
Posted on Dec 13, 2017
SOURCE:
  • 334 Answers
SOURCE: carrier Comfort zone 2 is flashing e1 after a storm/power outage
HEY THERE, DID YOU TRY POER CYCLING THE UNIT? TURN IT OFF AT THE BREAKER THEN BACK ON
SETH
Posted on Jun 27, 2009
  • 38 Answers
SOURCE: Carrier Comfort Zone 2 flashing E2
the e2 error on your thermostat is a problem with the return temp sensor on your system, the only thing you can really do is call a company and replace it, you can't bypass it or remove it cause the system wont run properly
Posted on Jun 30, 2009
  • 614 Answers
SOURCE: Carrier Comfort Zone 2 Master is flashing E5
Check float switch. E5 is loss of 24 volt power on some models.Russ
Posted on Jul 27, 2009
  • 614 Answers
SOURCE: The Carrier comfort zone thermostst displays the
Go to panal and reset control. Small reset button on control board. Let me know if it clears.James
Posted on Mar 25, 2010
tbreeze47
  • 3083 Answers
SOURCE: Our Carrier Comfort Zone II
This .pdf file may be of help to you:
www.brivis.com.au/.../Carrier%20Comfort%20Zone%20II%20Owner's%20Guide.pdf
Perhaps you could get some help from Carrier Support here:
http://www.residential.carrier.com/support/index.shtml
I noticed they have an option of talking to an engineer, and perhaps they could explain how to reset or set the unit.
Hope this helps.
Posted on Sep 25, 2010
My carrier comfort zone II thermostat is flashing E1. What does this mean and why am I having trouble setting my temps?
I suspect that if you change the battery in the thermostat. All will be right again.
Thanks for choosing FixYa.
Aug 27, 2011 | Carrier Heating & Cooling
E1 flashing , a/c quit working
Good Morning, Lets see if we can get you back to being cool. Not all units this works on but most.
The e1 problem is a timer that is pretending to demand that you clean the filter. It stops the machine every 720 hours and forces you to do a procedure to get it to go away.
There are 2 possible procedures.
1) Unplug the machine. Hold down the power button while you plug the machine in and wait for a beep about 5 seconds long. Let go of the power button. Unplug the machine. Plug it back in.
2) Unplug the machine. Hold down the mode button while plugging the machine back in and waiting for a beep of about 3 seconds duration. Let go of the mode button. The machine will start. Turn the machine off by pressing the power button. Resume trying to use the machine normally.
If these don't work, the "demand to clean filter" timer is broken and you will need to buy parts to repair the machine.
Let me know if this helps.
Aug 03, 2011 | Comfort-Aire Heating & Cooling
Our Carrier Comfort Zone II thermostat, which has 2 zone readouts, currently shows a temperature of 00, as in zero zero, on one zone. That is the main zone for our home. Zone 2, for spare bedrooms, etc....
Hope this helps.
Sep 25, 2010 | Heating & Cooling
We have the same problem, was hit with lightning and came up E1
You didn't get a Carrier tech. Carrier technicians only work on commercial equipment. Residential applicaitions, installation and service of Carrier residential units are done by dealers. They are not carrier owned but get buy the product at discount get training and get to show our logo. You can't fix the boards, they have to be replaced. It sounds like you have a Gen II VVT system. You can get the part via Totaline stores or a distributor. You will need to know how to readdress the other controllers to operate correctly. Use WWW.Carrier.com.
Aug 03, 2009 | Carrier 38CKC060 Air Conditioner
Jul 27, 2009 | Carrier 38CKC060 Air Conditioner
Jun 29, 2009 | Carrier 38CKC060 Air Conditioner
Carrier Comfort zone 2 is flashing e1 after a storm/power outage
SETH
Jun 27, 2009 | Carrier 38CKC060 Air Conditioner
What is the cooling btu on my BDP company division of carrier
is this unit real old ? it does not come up in my book . the btu is 30000 that is the same as 2.5 ton it may be 6,7 or 8 seer i dont think its a 10 seer because the 10 seer units are listed and yours is not . if this sounds wrong please look up the mod # again and post the ser # too ......... Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 15, 2009 | Amana Comfort Zone 12M32PBEH Air...
Heating & Cooling Logo
638 people viewed this question
Top Carrier Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
