Question about Whirlpool Freezers
How do I find the defrost timer on a 1993 Upright Whirlpool freezer Model EV200N
    Sergeant:
  • 259 Answers
Https://www.repairclinic.com/RepairHelp/Freezer-Repair-Help
This site has diagrams, wiring, schematics, etc.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Posted on Dec 15, 2017
SOURCE:
HVACRH20
  • 237 Answers
SOURCE: Whirlpool Freezer Model #EV150NXENOO
This one sounds like the defrost timer is not working and you are not getting a defrost cycle every 6-8 hours (or when needed). Another issue could be that air (moisture) is getting in from a leaky door seal, etc. and causing the freeze up. If you have a sealed system problem where the cooling coils are not uniformly frosted up then the defrost thermostat will not "know" there is an ice condition and therefore not go into defrost mode (same issue if the defrost t-stat is bad). After you have ALL the ice out of the unit it would be a good idea to take the interior rear cover off so you can view the coils. Start the freezer back up and watch over the next 1/2 hour or so to see that the entire coil is frosting up uniformly. If it isn't you may have a plugged system, a leak causing low refrigerant, etc. If over time the coils look uniformly frosted up you may have a defective defrost heating element itself (no heat, no defrost sort of thing). The defrost elements can be checked with a multimeter for continuity if you know how to do that sort of thing. It's hard to know a person's ability by these forums or if they can tackle certain test procedures.
Posted on Nov 13, 2006
  • 1314 Answers
SOURCE: My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
Posted on Sep 11, 2008
diths_kri
  • 67 Answers
SOURCE: Frigidaire Upright freezer FFU20FC4AW2
Sounds like the timer could be getting stuck and not releasing the defrost cycle
Posted on Jan 07, 2009
woodchuck789
  • 4070 Answers
SOURCE: My upright freezer won't self defrost. Frost builds up right awa
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Posted on Sep 19, 2009
  • 4793 Answers
SOURCE: ge upright freezer, like 1988 - model # says ca 21 dkc rwh
by the time you have fixed any faults,you might just as well buy a new(er)more effecient f/freezer.cost you less in the long run(got mine from a garage sale,owners were moving far away....)
Posted on Apr 07, 2010
How do I find the defrost timer on a 1993 Whirlpool upright freezer Mode EV200N
Look behind the kick plate at the bottom of the unit. Take it off, using either clips or screws holding it in place.
Dec 12, 2017 | Whirlpool Freezers
Whirlpool Model EV090FXK compact upright freezer does not run. Sat for over 15 years. Any manuals available for this old freezer?
The thermostat may be stuck froze in open position, in off and not closing, calling to replace the thermostat or the defrost timer
Jul 18, 2017 | Whirlpool Freezers
Freezer not defrosting
could be defrost timer or heating element broke
Apr 17, 2015 | Whirlpool Upright Freezer EV161NZRQ
Drain tube opening clogs with ice inside freezer.
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com and provide your full name, phone number, address and the model and serial number for your freezer.
Apr 01, 2017 | Whirlpool Freezers
I have a Whirlpool EV200N upright freezer, 19.6 Cu. Ft.. It has a build up of ice on the inside at the bottom. It is nowhere near the drain hole.
syringe the drain with neat clorine bleach to clean it out just in case its blocked.use car deicer to clear existing ice (not hot water)and see what happens...
Aug 26, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Our 4 year-old Whirlpool Upright Fridge/Freezer model 2FHKXXKQ03 repeatedly trips out on the defrost cycle. We live on a small island in Moreton Bay Queensland and without any Island-based technical...
check the timer maybe your Fridge it has timer to defrost or is set to auto defrost try to make set to manually defrost..or if you have manual of that item read it for guidance..
Apr 02, 2010 | Freezers
Freezer is on and just stopped working
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 16, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
My Whirlpool upright freezer keeps building up ice inside the bottom back wall. The fan starts rattling and freezer will not stay cold enough to make ice. If I take everything all out and leave it off...
Either your defrost timer, defrost heater or defrost thermostat has failed. All parts are located behind the lower back panel inside the freezer. Most likely are the defrost heater and defrost thermostat.
Jun 09, 2009 | Whirlpool 20 cu. ft. / 566 liter Upright...
Whirlpool Fridge Model WRX57H Defrost Timer
if you couldn't find a defrost timer then just unplug it or switch it off until all the frost (ice) melts!
Nov 19, 2007 | Whirlpool 19.6 cu. ft. Upright Freezer...
Defrost timer
What is the complete model # on the sticker inside the freezer?
Oct 23, 2007 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezers Logo
65 people viewed this question
Top Whirlpool Freezers Experts
AJMAL KHAN
Spencer Field
Spencer Field
Level 1 Expert
Steve Allison
Steve Allison
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
