Troubleshooting Treadmill Control Panel Issues Green Fitness Company
However test the voltage supply from Control Board Motor to the PCB console, by 8-12Vdc, if does NOT appear replace the Control board motor.
If there are Replace the Console Board Display.
Blessing.
[email protected]
cell+whatsAPP:+50588611441
SOURCE: looking for repair manuals and error codes for
Could you please advice about ERROR 29 fo C956i/C966i treadmill.
SOURCE: The ramp will not go up or down. It's states low
The ramp system has a battery monitoring system. If the battery voltage falls below 11 Vdc when the ramp movement is initiated or the battery voltage falls below 10 Vdc after ramp movement has been initiated, ramp movement will be stopped and gives that error message. The ramp will not be enabled until such time as the battery voltage exceeds the above limits. The battery voltage must be raised to be to correct this problem either by charging or replacing the battery.
SOURCE: I have an efx 546i and when I try to use the
SOURCE: where do you find the
you must have an incompetent boyfriend ... chuck him out then throw the machine out on top of him ..
SOURCE: How do I replace the
You may have to purchase the belt from a Precor dealer in you area, if you don't have one then call Precor directly @ 1-800-347-4404 and they will help you. Most of these part have not hit the secondary market yet and Precor pretty much call the shots on whom the sell parts and support to.
There is a place on line to get some of these, it is. www.treadmilldoctor.com/Products-Services2/precor-treadmill-belt.
The manual can be found at. fitness.manualsonline.com/ex/thread/view/idThread/2141832
This place has manuals and user manulas along with support and some partswww.shopwiki.com/Precor+EFX+5.171 I believe this unit has a 10 yr warranty with it and the part in question may be covered by them. There is also a 1 year part warrant for other parts, I just don't know what parts they are covering for the 10 yr.
