The coffee machine does not make any noise that it is heating.
Hi
Quite possible the boiler has failed. You would need to disassemble to check (with a multimeter) if the boiler heater elements are a continuous track from one terminal to the other. Boilers often fail - else you have a electronics problem somewhere that will require a tech person check out.
The other thing boilers can do is to develop an earth leak between the heater element itself and the outside of the element - this will cause the machine to shut down your house's power supply if you have an Earth Leakage Safety Switch installed in your meter box.
Given this was an inexpensive machine and uses rather "odd bod" pods it may be time to consider something more 'common' like a Nespresso, Aldi or the Cafitaly style of capsules.
I especially like the Cafitaly capsules as they have more coffee than Nespresso, have 2 internal filters, can be refilled with ground coffee (I reseal top with wide cellotape) and can be refilled at least 4-6 times before they should be thrown away. Instead of around 30-50c a cup, refilled capsules costs me about 9c a cup - I get about 100 capsules out of 1Kg (2.2 pounds) of coffee.... beat that.
Cheers
Mike
SOURCE: philips senseo coffee is watery
It may be the pod holder,there is a seal under the black disc at the bottom of the holder,the water will bypass the coffee under pressure,travel to the outside of the pod holder and exit the centre where the filter mesh is,if there is no foam also this is a sure sign,fill the empty pod holder with water and see how quick the water drips,I had this same issue and bought a new pod holder and compared,should be no more than 1 drop a second,you can knock the plastic out and re seat the O ring or buy a new holder,hope this is of use to you
