There could be several reasons why the buttons on your Nautilus T9.14 elliptical trainer are not functioning regularly. Some possible causes include:
- Damaged buttons: The buttons on the console may be damaged or worn out, and may need to be replaced.
- Loose connections: Make sure the connections between the console and the elliptical are secure and tight.
- Dirty or sticky buttons: Clean the buttons with a damp cloth and make sure they are not sticky or dirty.
- Firmware issue: It could be a problem with the firmware of the console. Try to check if there are any firmware updates available for your elliptical and install them.
- Power supply: Make sure that the power supply to the elliptical is working properly and that the outlet is providing the required voltage.
- Damaged console: If none of the above solutions work, it could be a problem with the console itself and it may need to be replaced.
It's worth trying these solutions one by one and check if the buttons start to function regularly. If the problem persists, it would be best to contact the manufacturer's technical support for further assistance. They may have more specific troubleshooting steps to help you fix the issue.
