New pump, new disel filter, new oil filter.
SOURCE: 2001 cavalier barely starts,sometimes runs
Three things.
First, you need to check the MAF sensor for contamination.
Second, check fuel pressure, if you dont have a gauge, autozone and Advance have them on their tool loaner program.
Should see 35-40 psi with key on engine off, cycle key a few times, if it takes a while to build up, replace filter and retest.
Third, possible convertor blockage, easiest check is to remove the 02 sensor and try to start with the hole open, if it runs, then that is it, specs allow for 2-3 lbs of back pressure max. That means if you can hear pressure escaping, it is a problem area.
SOURCE: fuel pump not staying on 1993 k1500 350
Some GM products also incorporate the oil sender switch into that circuit for fuel pump, so that in case of an accident, engine shuts off, oil pressure drops, in turn, shuts off power to fuel pump. May be worth a look at what your getting for oil pressure, as well as checking switch/sender.
SOURCE: car wont start
check your fuel pressure it should be 35 psi .fuel pump relays dont go out but check all fuses with test light there is a fuel injector fuse but most likely problem is your fuel pump!
SOURCE: 1992 toyota celica gt 2.2 starts runs rough then dies
Sounds to me like the fuel pump is worn out. They DO wear out. And even though they seem to be working, the brushes in the electric fuel pump may not be contacting all the commutator, thus making the pump weak. It may start the motor but can't maintain normal running pressure (27-35psi). Have you run the car out of gas shortly before this problem surfaced? If you have then it's your fuel pump. It was damaged when the tank ran dry. Even though the pump may seem to be working, it's still badly damaged and needs to be replaced.
Just as Matmenzies has stated, get a fuel pressure gauge and test the pressure. I'd start with a complete check of all your vacuum lines. Check for cracks on the vacuum hose that connects to fuel pressure regulator on the fuel rail. Also, if you can, get a hand operated vacuum pump to check the regulator. If you can place a vacuum on the regulator and it holds, I'd say move on the fuel pump and check it.
BTW, if the fuel filter has been changed, you may want to check to see if it was installed backwards! Some fuel filters are valved and will cause symptoms like this. However, this is an immediately noticeable mistake and you haven't provided enough info for me to say more. I'd pull it and check that it has any flow at all. You could have sucked in a big dirt ball and blown it right into the new filter, effectively stopping fuel flow. Then I'd blow out the fuel lines, just to be sure.
Start with these 2 things and post what you find. We'll go from there.
