Televison & Video Logo
My radio shack 4in1 light up remote doesn't say dvd on , can i still program my dvd with it?
5 Related Answers
Anonymous
  • 65 Answers
  • Posted on May 28, 2008
SOURCE: i lost my manual i have a radio shack 4in1 universal remote no.15-2114
if you have a universal remote try their website, you can also try hitting the power button on the remote severl times(maybe hundred) intil your tv turns on, then hit the enter button, this will program the tv...
freetek
Steve Allison
  • 5569 Answers
  • Posted on May 18, 2009
SOURCE: need codes and instructions for Radio Shack 3 in one remote programming
First, you need to realize that there is no such thing as a 'universal remote.'  At best, they are multi-brand remotes.
You might get lucky if you try any codes you have (or can retrieve from the Tandy website) if you check these brands too:
Funai, Symphonic, Sylvania, Emerson, Aventura, Durabrand, ESA, Magnavox, INSIGNIA, and Misakai
They are all made by Funai, one of the worst manufacturers in Asia.
Anonymous
  • 4090 Answers
  • Posted on Sep 24, 2009
SOURCE: Need remote control code for Radio shack 2-in-one.
0053 is the only JVC code in the master manual
Please rate the help++++Thanks for using FIXYA
Testimonial: "You provided the right code for my JVC. Remote now works perfectly. Appreciate the help."
S. Gontko
  • 142 Answers
  • Posted on Mar 15, 2010
SOURCE: Program Radio Shack 15 2142 remote for converter box
only if the converter box is using older codes that were in use when the remote was made.
Anonymous
  • 616 Answers
  • Posted on Oct 30, 2010
SOURCE: Need to program the Radio Shack Big Botton Remote
Try google
What is problem with TV described in detail?
Hi my name is Lena I have a sense 22-in LCD TV DVD built-in model number s2201 ac120 volt 60-hz, power consumption PC 52w. And I have a radio shack remote 3 in 1 15-1916 remote that I'm trying to program to this TV. Although the DVD doesn't work on the TV, there was a VCR / DVD playerconnected to the TV but it had its own remote. So I want this radio shack three in one remote programmed to the since 22-in DVD flat screen programmed. I just don't know how to go about it. Can you please help me.
2answers
Can someone help? I have a Curtis LCD3273A tv and a Radio Shack Family Favorites 4in1 universal remote. I can't find the code. The power button doesn't work on the tv. Please help. Thanks
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Need tv codes for a radio shack 4in1 family remote ??
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
Remote code list
Hello
Get into this link, by copy and paste the link into the address bar of your browser. You can download the manual for your remote control from here.
www.ask.com/questions-about/Radio-Shack-3-in-One-Remote-Codes
I have a radio shack universal remote and am trying to program my dvd player to it; I have however lost my manual. the dvd player is an apex
It would be helpful to have the model number for your 3-in-One remote. However, most of the codes are common for your Apex DVD player. These are codes a RadioShack Remote for an Apex DVD player. 0672, 0717, 0755, 0794, 0795, 0796, 0797, 083. Press the button for DVD on your remote. Then press and hold the Program button until it blinks. then, enter your 4-digit code, after entering, the Program button will blink. Aim the remote at the DVD and press the Power button on the remote. If the DVD turns off, then the remote is programmed for the DVD player. If not, repeat instructions and enter another code, until one is found that will turn off the DVD when the power button is pressed.You can also download an owners manual from RadioShack.com with the model number of your unit.
Need the codes to radio shack 4 in 1 remote
have you tried www.remotecentral.com
try this link:-
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?kw=radio+shack&area=
or
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=dishnetwork&dv=universalremote&md=15bluebutton4in1&kw=radio+shack&st=&ar=&dt=&so=&pg=1&file=others/dish/4in1-manual.zip
2answers
I lost my manual i have a radio shack 4in1 universal remote no.15-2114
Top Radio Shack Televison & Video Experts
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
