The hertz output of the gen is directly proportional to the RPM of the engine speed. You need a meter that you can monitor the Hz and then adjust the engine speed until you are right at 60 Hz.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: I need to set cycle to 50 down from 60 Hz
This unit can not be reset to cycle to 50. To find a unit that could be used at this cycle please call the Andis customer service line at 1-800-558-9441.
SOURCE: frequency adjustment or solution
Can you check the RPM of the engine? 3600 RPM = 60 HZ. If it is running around that speed, try a different frequency meter.
If it was producing 180 HZ, it should automatically shut down and show a fault code!
It be better to obtain an unit that already design for your area as it will the appropriate electrical outlets.
As for the 30552-00 would be 60 Hz with running at a governed speed of 3600 (3750 unloaded).
Being a two pole generator frequency is determined by dividing engine as follows. 3600 / 60=60. Engine is RPM is in minutes and must converted to seconds. For 50Hz operation the engine speed must be reduce to 3000 rpm (50hz * 60seconds = 3000 rpm)
