Question about Samsung HLR5067WX 50" Rear Projection HDTV
Green Plaid lines on Samsung HLR5067wax/xaa-
I am also experiencing green pl;aid lines throughout on all channels except HD channels. HD channels come in clear. Unplug reset for the day and up until recently worked. Set did have to warm up period but green plaid lines dissapeared and all channels were clear. Now even after reset only HD channels are clear. I am leaning toward the analog board, Also red temp light stays on. Any solutions?
  • 167 Answers
These are the Tests that should be run to determine which board is bad.You should call a good TV Tech if you are not familiar with this TV.
- The DDP1011 on the DMD board has a feature to display internal test patterns.
- DNle, which is an end port in the digital board, has a feature to display internal test patterns.
- The analog board sends signals to ADV7402 on the digital board.
- The analog board is the first output and the digital board is the second one, followed by DMD, which is the final one.
■ Diagnosis By Module
1. Access Service Mode
(In Standby mode, press "Mute", "1", "8", "2" and "Power" to turn the screen on and enter service mode)
2. Check if there is an error in the DMD board
DDP1011 → TEST PATTERN → Press the right arrow key:
Options of FULL WHITE, BLACK, RED, GREEN and BLUE PATTERN are displayed on the screen.
If "Pattern" does not appear, this is a DMD board error.
3. Check if there is an error in the digital board before the DMD.
When the DMD board has been determined to be error free based on the test patterns:
FACTORY MODE → DNIe → TEST PATTERN normal display: no error in the digital board.
If "Pattern" does not appear, it may be from a DMD board or ATI error or there is an analog board malfunction.
4. Check if there is an error in the analog board.
Check for a power signal from the analog to the digital boards
Posted on Jul 30, 2009
SOURCE:
I have a Samsung Hlr5667wax/xaa DLP TV and the screen has gone green/green plaid pattern.
when the color wheel stops the picture will be all over the place. and you will have lines when it starts to fail as its not going fast enough for the picture. wining sound is it wearing out.
May 29, 2017 | Samsung Hlr5667w 56-inch Dlp Hd Tv
I have a Samsung HLR5067WAX/XAA 56 inch, rear projection. Replaced lamp on it two years ago, was working fine. This morning a sudden thunderstorm blew in. When the power came back on, the cable picture...
Hi,If your tv is a dlp you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Here's the instructions to replace it http://www.fixyourdlp.com/guides/samsung/bp96-01579a.php and your part # is BP96-01103A Have a bless one!
Apr 26, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Green Plaid Screen
Are you able to access the on-screen menus (like brightness/contrast etc)?
If those menus are appearing over the green screen, then it might be a cable or image source problem. I've often seen this green screen when the HDMI encryption between my cable box and my TV gets messed up. Only solution has been to power cycle the cable box.
If you can use something other than an HDMI cable to connect your TV to your picture source, I suggest trying that and seeing if you can get SD channels again. If you do get them back, it was a cable issue. If you still can't get them, contact your cable/satellite provider, see if there's something up with their signal.
May 30, 2009 | Samsung HLP5067W Television
Green Vertical Lines across screen- Sansung HLR5067WAX/AA
Hi, your are experiencing the first stages of a light engine burn out. it will fail soon. i recommend replacing the light engine asap.
Samsung Part Number: BP96-00822F---$895.00
May 22, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Green Plaid then Vertical Lines, Failure of hard controls, Analog Board?
You are absolutely correct, When anyone complains of vertical lines or bars, the next step is to see if it happens on only digital inputs ( digital board ) , only analog inputs ( analog board ) , or both ( DMD board ) .
Analog board can be purchased at www.partstore.com ,
Jun 04, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Green Plaid Screen
I think what you are describing is a form of line paring which is caused by a defective IC in the video circuit those inputs are feeding. Post a email link ad I will send a pic of a screen that has this problem and you can let me know if thats what your experiencing.
Jan 27, 2008 | Samsung HLP5067W Television
Green Plaid screen
had same problem with ours. at end of one year had green problem and service replaced color wheel. know 1 year after starting to have same problem again. I will not buy this brand anymore.
Jan 27, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung HLR5067WX 50" Rear Projection HDTV Logo
1,725 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
