SOURCE: GE Model JTP15 oven shows F3 error code
I have the same problem. I noticed that the oven gets to the selected temp ok. Then when the pilot attempts to RELIGHT, it gets the error F3. Did you get a solution? After other posts, I will see if the temp sensor is around 1100 ohm as suggested by others. Ken
SOURCE: F14 error message
First change the fuse. Then if it still isn't functioning properly, you may have to replace the lamp, in which case you should contact a specialist. Details can be found in the Instructions Manual.
Go here:
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
and enter EB270 and click the Go button.
Then download the PDF file of the manual in English (EN)
Hope this helps :)
Chris (ziraffa)
ps Someone else on Fixya claims to have fixed the F14 problem by changing the PCB Board, whatever that is.. but there was no further rating or feedback given. That's all I have.. Good Luck!
SOURCE: My thermador oven tells me error code 14
Sometimes you can unplug the unit for at least 30 minutes and reset the unit and it wont do it again.Try that first. An error code on a thermador of 14 means latch switch problems.
SOURCE: error code f7 on Kenmore wall oven 911.41165791
Try this first!
The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. If that does not work, repalce the defective parts yourself. You can do it for about 30% of what a repair company would charge. it's either got to be 1. Control panel 2. Relay panel. Good luck!!!
SOURCE: kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure
Code
F0 - E0
Analog to
Digital Failure
Disconnect
for 30 seconds - if display re-appears - replace control
F1 - E1
Safety flip
flop
Replace Electronic
Range Control/Clock(ERC)
F2 - E0
Shorted keypad
Replace Electronic
F3 - E0
Oven temperature
sensor or oven temperature sensor fuse opened
Replace oven
temperature sensor or fuse
F3 - E1
Oven temperature
sensor shorted
Replace oven
temperature sensor
F3 - E2
Oven too hot
Replace oven
temperature sensor
F3 - E3
Clean temp
too hot
Replace oven
temperature sensor
F5 - E0 F5
- E1 and E2
Check door/latch
switch
Replace component
2 Digit Failure
Code
F0 or F1 or
F5
Failed transistor
Replace Electronic
F2 - E0
Oven temp
too high
1. Test
operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
F3
Thanks
