Hi Janet.
all i can find out is,ebay sells all john lewis needles.so if you go there and put in your make and model number it might find the size you are trying to find out.
or again go on the the google page and put
What size needle does a John Lewis mini sewing machine need.
but make sure you put your model numbers or any other numbers you can find.on there as well.
is the needle inserted correctly?
is it the right needle for the fabric being sewed?
it's possible that it could also be a timing problem, which means it would have to be check at a sewing machine shop
The motor is tired or dry and perhaps the belt is slipping.
