Anonymous Posted on Jul 29, 2009
Hi I would like to know how to wire up a kam keq 15 dual band graphic equalizer to my home hifi thanks
  • Anonymous Jul 30, 2009
    Thank you chief101 your a star i was not too sure if I needed hifi that went with it, thanks again Mick
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Jul 30, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
3845
Points
11
Either run the main ouptut for your amp to the input of the eq and output of the eq to the main input of your amp OR use one of your tape monitors on your amp. Record on your amp goes to eq input and play on your amp goes to eq output. Hope this helps you.
Can I download and print the manual for the ART 355 Dual 31 Bank Graphic Equalizer
Simple, how much instruction would you need? Check here http://www.manualslib.com/manual/210377/Art-355-Eq.html
How to setup my Mixer XENY X222 to equalizer FBQ3102. tnxs God Bless. .. . . .
Hi, This will be pretty straightforward hopefully. all you should need to do is connect ANY " LINE OUT " from the mixer into the " LINE IN " or anything marked audio in on the back of equalizer and you should be in business. Thank you for using FixYa, and I hope this helps, Be sure to write back if this helped or even if we need to be of more assistance,ggood luck Prodzilla
1helpful
2answers
I need a wiring diagram for the pyramid 10 band graphic equalizer. Where can I find this diagram?
Click on MANUAL DOWNLOAD
LOOK PAGE 4 INTO THE PDF FILE!!!!
http://www.pyramidcaraudio.com/sku/903G/10-Band-Half-Din-Power-Booster-Graphic-Equalizer-Amplifier-200-Watts#
21helpful
2answers
Power supply connection for pioneer eq-6500
top left - orange.....goes to aux or memory wire
top right - blue.......goes to the remote wire used with amps
bottom left - black.......goes to the ground wire
bottom right - red........this goes to your hot wire
How to hook the eq up??
take output from left and right from equalizer and go to line in any two channels inputs in peavey mixing console and adjust your level with faders and other control knobs.
Hi. i want to add a graphic eq to my pioneer receiver (home audio).
if the Eq has enough jacks to run every thing, that would go In to Eq an out to receiver, you were told correctly, for example cdplayer out - to Eq In - Eq- out to Receiver in
 Grubhead
Grubhead
SmartAviator
SmartAviator
