I have a sears upright frost-free freezer, manufactured in July 2003, model # 253.23024101 which I purchased new. For the last couple of years, about every three months it accumulates about a 1/4 inch of ice on the inside floor of the freezer, and over the drain line to the evaporator tray underneath, and water then leaks onto the floor. On April 15, 2009 I replaced the defrost thermostat and the defrost heating element and the problem still persists. I also checked the drain line to the evaporator tray underneath the freezer. When it leaks onto the floor, I have been chipping the ice away and using a hair dryer to remove the ice that develops in the drain line and then pour a cup of water down the unfrozen drain line and the freezer is fine again for a couple of months. Any ideas?
I have had the same problem with my frigidaire/electrolux upright freezer... I am researching to see if there is a pattern. Once or twice a year for the past few years, the freezer defrosted itself. I found the outside of the unit to be VERY hot to the touch around the time that this occurred.
We typically unplug it for a chunk of time when this happens and then replug it. It has always begun working again.
Sadly, we have lost many groceries and have had to clean many bloody meat messes as a result of this. ANYONE buying this freezer should save their receipt... That way, they can return it or have it repaired when it fails. I hate to think of sending all of these failing monstrosities to the landfill... =(
There is a curing process for the foam used to insulate these. It can give off a pungent odor until it is fully cured. Only experienced it a couple times in the last 20 years. eric
It sounds like the unit is low on freon or the compressor is going bad. You have several other components that could be affecting this as well. Make sure the coils are free from dust and clean underneath. This is a bit premature for you to have problems now, especially since it is a Sears product.
hi thanks for the question its normal for a frost free freezer to run a long time to keep a good cold temp i don't think you have a problem thanks the appliance doc
