yes there is a kit you can use. most diy shops that sell cooker fixings etc will have them. they usually stainless steel and you have to cut them to size you need. and make a square with it. backing with bits of wood to the size of the hole need to put the top on and the stainless steel to cover the wood that has been put in. you can make your own. by filling the hole with wood strips get from a timber yard or store have them cut the size you need. then fix them to the open part you need to fill. leave a lip ( this is to put the stainless steel to. check it all fits. then get the strips of metal to fill the hole making sure they the right size glue them down to the strips of wood you have put in then put the top on. jobs a good one. don't nail the wood in place put 4 good long screws in each piece of wood gives it strength then.
filter size of the Coolpix 8800 is 58mm, you might find single piece adapter/converter rings on ebay...... assuming the Heliopan's are 77mm.... try searching "77 58 ring" but you might have to get 3/4 rings to bridge the difference. Eg. 58-62mm, 62-67mm, 67-72mm, 72-77mm
I would contact customer service and ask if they have "drop-in" replacement. That was a Daewoo made for Amana / Maytag / Whirlpool. Their customer
service is here.
What you need to do is check you fuel pressure. Go to a local auto parts store and buy a fuel injection pressure tester. The pressure fitting is on the top of the motor its a 3/8 ish sized metal line and has a screw on fitting like a tire valve does. This line comes up from the back of the motor to the right of the distributor and goes down into the intake. Make sure to have a rag handy to catch the fuel seepage. After you connect the pressure tester turn the key on and off three times and read the gage you should have atleast 58 pounds of pressure. If you have 56 pounds it won't run because the fuel injectors are a poppit valve style and need atleast 58 pounds of pressure to operate.
The best thing to do is to call Carriers customer service line or their tech. support number... often times the customer talking to the co. directly will get better results then the dealer talking to them...
The dealer does need to recover thier costs also... they do not make that much money on the initial installation...
It is worth a phone call or two for you to call the factory and tell them how you are going to tell all of your friends NEVER to buy any carrier products because they do not stannd behind them!!!
