I have a Stepmill 7000 pt. Recently I have a terrible time trying to start a program like quick start, manual, fat burner, etc. I have to push the program button multiple times to start the program. Then when console finally accepts the program, it will reset. For example, I'll be entering weight or level in the manual program and the console will reset back to default display. On top of that, once I finally get the console to accept the workout program and I am exercising, it will stop abruptly and reset to default display. Sometimes it will stop 2 minutes into my workout or it may be 15 minutes. Very random on when step mill will stop and how many times it will stop during my workout. When it stops abruptly, I will again have a terrible time trying to start a workout program like fat burner or manual and have to push the program button multiple times to start the program.
SOURCE: Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
SOURCE: 2000 beetle will die at random times, and will not start for about 15 minutes!
this can be caused by a bad fuel filter or dirty injectors. try a bottle of fuel injector or fuel system cleaner in a tank of gas. i suggest lucas products which can be found at any parts store.
SOURCE: Kitchenaid KAWS750JQ3 Top Load Washer
hi there,
make sure that the program is not on the "Intermittent Agitate Program". that would be the cause of the delay.
the other issue would be the timer itself. the timer is mechanical, so once the contact on it is corroded, it will only function intermitently or not at all.
please let me know if i can be of more help.
thanks
SOURCE: Lg Plasma Display settings keep switching
When you boot up your tv for the first time, you get to choose between home and shop-mode.
In your case, he TV is set to "shop-mode".
Then it will go back to factory settings after 5-10 minutes. (so that customers won't mess up the settings all the time)
So change the settings from shop to home, and your problem is fixed!
