Computers & Internet Logo
S
Sheila Julian Posted on Dec 05, 2017
I seem to be able to get Netflix during the day,but not at night. It has been this way for a week-10 days. It says " try again later" I am paying for this service & not getting it....
  • Brett Duxbury
    Brett Duxbury Dec 05, 2017
    Hi Sheila Julian, What internet plan are you on ?
    Is it a cheaper plan that might slow down your internet speed causing grief with netflix ?
    Can you please add details in the comment box?
  • Anthony Cardenas
    Anthony Cardenas Dec 05, 2017
    SOME providers "share" Internet data lines with other users in your neighborhood ~ almost like a "party line"... Of course at NIGHT there are more people online and hence, TOTAL network speed in your neighborhood may all suffer the same 'overload'.
    ALSO! Have you heard about "Internet Neutrality"? OBAMA allowed Internet providers the ability to "THROTTLE-BACK" your speed when connecting to services just like Netflix, Amazon and others trying to d/l movies and even YOUTUBE!
    Now if Netflix wants to PAY your Internet provider to send more/faster data to YOU (like it WAS), your provider will pay up. You are both 'victims' in this situation.
    Anthony
playdayrider
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 8 Answers
  • Posted on Dec 05, 2017
playdayrider
Contributor
Level 1:
Welcome Back:
Answers
8
Questions
0
Helped
2131
Points
21
I had this problem as well. Try this:
Assuming you have a dual band router, set up a second network using 5.0 GHZ instead of using 2.4GHZ. (I named the 2nd network with a '2' after the same name as the other one.). You'll need to get into the configuration of the router. There should be a manual for it online somewhere with the instructions and the URL. Then, just change the wireless in your TV (or device) setup to the 2nd network. This should work. However, it won't work if your device is only capable of the 2.4GHz band. Since some devices are not dual band capable, you might want to keep both networks. Also, if you can do this, should also increase your internet speed as well. It nearly doubled mine.
You may also try changing the wireless channel within the router.
Good Luck.
5 Related Answers
heatman1976
  • 19 Answers
  • Posted on May 17, 2009
SOURCE: My Honeywell chronotherm IV Plus thermostat intermittent problem
The Chrono Therm 3 and 4's were some of the worst products that honeywell has EVER put out. I would suggest switching to the Vision Pro 8000, please consult your local HVAC company for more information regarding the change over.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cody_17f08cf8e340c06c
Anonymous
  • 72 Answers
  • Posted on Jun 13, 2009
SOURCE: my bottom oven will not heat
More than likely you have a bad ignitor, it works like a glow plug, it heats up, when it draws around 3.2 amps, it opens the gas valve and ignites, it stays on for the duration of baking/broiling. Like a light bulb, it has a finite life, I would do an amp draw on it, if it is drawing less than 3.1 amps then it is time to replace the ignitor, should cost around $40
ROB
  • 858 Answers
  • Posted on Jul 20, 2009
SOURCE: CAR WILL NOT START, HAD ALTERNATOR REPLACED,
check that nothing is left on & that all lights are off check the trink light is off !!
otherwise its a auto electricians job ok
Cheers rob
Anonymous
  • 65 Answers
  • Posted on Jul 24, 2009
SOURCE: Date Changes during the day
Hi Jeffrey, Put stem into "set hands" position and adjust hands to the 12:00 position. Day and date should advance at or close to that time. If you pass 12:00 and there's no change continue rotating another 12 hours and they should advance. Once youv'e found that there's midnight so if you're setting the time at say four (4:00) in the afternoon (pm) you will neew to rotate the hands so around the dial so they pass 12:00 once more then four hours more to 4:00. Now I assume by bilingual you mean that the day ring has like Mon (monday) and Lun for Spanish or the like. In this case if it's showing the wrong languare set the crown (winder) to the first position (second posn is "set hands) and rotate winder eithr clockwise or anticlockwise. Once you discover how to advance the day ring just set it to the correct day/language you want and press the crown home. Hope this solves your problem. If the advances are changing at some obscure time like 8:40 or something it's because the hands pave been located incorrectly and would need correcting by removing movement from the case.
Testimonial: "Perfect- very detailed and easy to follow. Thank you!"
Anonymous
  • Posted on Dec 02, 2010
SOURCE: White lines in pictures taking during the Day
sdfa
I have turned my fridge freezer off during 5 weeks. Since I'm back it's back on again, it cools and the freezer is freezing... but every day it rings and indicates that the freezer temperature (the re
Laurie a lot of people forget to leave the fridge and freezer door open slightly and the water from defrost hiding behind the rear wall of the freezer will keep the inside of freezer and fridge damp this will cause the freezer fan motor to rust and stop air circulation. Can you provide a model number? Thanks John Tripp Appliance 911
Contact me Here
Roku com support
Did you try again later or the next day? If so without any results, then you should try customer support of Netflix... their number is 800.585.7265.... I wish you luck with your Netflix connection.
Aug 21, 2014 • Netflix
I have a Roku 3 which uses the Internet to access Netflix. My ISP gives me unlimited access during 23.00 and 07.00. Is it possible to down load a film during these hours and view it a few hours later
Netflix will only load the stream for a short time before it stops, streaming must be done live but you could pause it but doing so all night would not be of much help. Just start and hit pause 10 to 20 minutes before you really want to watch a film or show. If this is really a problem you may need to improve your internet capability either through increasing speeds, getting a plan with less throttling, or moving the router closer to or connecting directly to your devices. Other than that you could download movies and avoid the problems of streaming altogether.
1helpful
2answers
Error code 24105 trying to connect netflix
i called nintendo about my issue with getting netflix to work after two hours and maybe four people later. nintendo tells me that there not sure how to deal with this issue to please try again later. i been trying for a good month now and nothing as of today. im not a happy camper with nintendo p.s. sony is way better solves my issues..
1helpful
Every night- at the same time- while watching Netflix on my Wii- through a WiFi connection- Netflix streaming will freeze, retrieve then fail. I can sometimes select Try Again and it will work for a short...
Hmm... I am not sure, but this can be because of your internet provider. Some IP's "reboot"their internet hosting servers to wipe all the non useful info that got collected over the day. I really dont know why you wouldn't be able to continue watching after the internet was back again.
Top The Computers & Internet Experts
Alexander
vince
Steve Sweetleaf
Steve Sweetleaf
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
