Question about Juki Sewing Machines
Which way does thread come off of bobbin for juki tl 2200 qvp
  • Juki Master
  • 12,731 Answers
According to the manual (pg 20), it appears the bobbin turns clockwise in the bobbin case. So when the bobbin is loaded and the thread pulled, the thread direction goes right, then doubles back through the tension mechanism to the left.
http://jukiquilting.com/media/catalog/product/t/l/tl-2200qvp_stand-up_manual.pdf
Posted on Dec 05, 2017
SOURCE:
yalmer
  • 552 Answers
SOURCE: threading a juki ddl 5530
Go to this link and you will find how to thread your machine.
Posted on Apr 02, 2008
  • 13 Answers
SOURCE: juki ddl-227 industrial machine
Before all else. Turn off machine!
(1) break screws on the hook loose.
(2) tighten one back up very skightly, one you can reach when the needle bar is at its lowest position.
(3) lower needle bar to its lowest position.
(4) loosen the screw just tightened.
(5) position the tip of the hook behind the needle hole. the tip should be as close to the needle hole as possible without actually touching the needle
(6) tighten screws
(7) slowly hand turn the machine (depress the foot pedal to disengage clutch brake on motor) several revolutions to make sure the needle doesn't hit anything on the hook.
(8) if it passes this test, try on a scrap of fabric
Posted on Dec 15, 2008
rylee_smith
  • 8619 Answers
SOURCE: my Juki DL 5555 won't pick up bobbin thread
It is possible that you have the bobbin in backwards. Try inserting the bobbin so that the thread pulls in the opposite direction than it currently does. Also, sometimes you have to really push the bobbin case in to make sure it snaps into place. Other than that, you may have a dull needle...try replacing it, or it just may need an overhaul.
Posted on Jan 30, 2009
  • 161 Answers
SOURCE: I recently purchased a Juki
perhaps you have the wrong needle or its not in the proper position?
Posted on Sep 12, 2010
SOURCE: I have a Juki DU
Be sure you have the proper needle - it is longer than standard needles, plus be sure that you put the needle in from left to right - not...front to back.
Posted on Apr 26, 2011
Cannot pull bobbin thread up on juki 2200 longarm
replacing the bobbin carrier has upset the needle/hook timing
readjust or take it to a machine shop to have it adjusted
Jul 24, 2017 | Juki Sewing Machines
Bobbin does not stitch
Have you changed your needle lately? Have you checked the needle/shuttle timing?
Nov 02, 2012 | Juki TL-98Q
I have a juki tl98q sewing machine for my mid arm. The bottom thread keeps bunching up and I cannot sew anymore. What can I do to fix this? Do you have a diagram to thread the bottom bobbin and the top of...
The threading diagrams are available in the manual which is available from Juki on the TL-98Q product page: http://www.juki.co.jp/household_en/pism/tl98q.html . The direct link to the manual is http://www.juki.co.jp/household_en/pism/img/tl98q/download/98qim.pdf . See pages 14-18 (pages 16-21 of the PDF).
There are a couple of things I recommend that you check. First, make sure that the bobbin is evenly wound. This is a function of the bobbin winder tension; see the manual (page 15) for that adjustment. Next, check if the bobbin case tension is correct. Place the bobbin in the bobbin case and dangle the unit from the thread. Try to shake the bobbin case up and down, sort of like a yo-yo. The thread should advance by a bit. If the thread length doesn't change, loosen the set screw on the side of the bobbin case a small amount. If you get a really long tail of thread, tighten the set screw. See page 21 of the manual.
Next check for any loose threads and dirt in the housing around the bobbin case. Depending on the length of time that you have been using the needle, replace the needle.
I hope this helps.
Sep 28, 2017 | Juki TL-98Q
Needle won't pick up bobbin thread tried cleaning new needle new bobbin thread upper thread..
did you clean the bottom bobbin area thoroughly? Remove the cover plate and bobbin reel, look for debris. Any left over cotton will cause problems, after you clean it spray some wd-40 on all moving parts.
Thanks
Adam
please leave me some feedback
Feb 18, 2011 | Juki TL-98Q
I have lost the manual and i dont remember how to thread a bobbin. Pleas help me and thank you!
Juki TL-98Q
Loading the bobbin into the bobbin case:
Snap in the bobbin case latch, and put the bobbin into the bobbin case so that the bobbin runs clockwise.
Passing the thread through the **** of the bobbin case, continue passing it under the thread tension spring, and pull out the thread open end about 10 cm from the bobbin case.
Insert the bobbin case fully into the hook, and close the bobbin case latch.
You can obtain a copy of the manual in pdf format for free at:
Jul 29, 2010 | Juki TL-98Q
I having trouble putting my bobbin in my Juki TL 98E. I can not get my bobbin thread to come up because of this. How does this bobbin go in properly?
Well you could one or two make sure that the bobbin is set correctly or make sure that the parts is not bent or out of place this would make the bobbin not work propery. Ok
Dec 15, 2009 | Juki TL-98Q
Juki TL98Q needle thread breakage
your bobbin it is not in his right position, quit tightin your tension.
Sep 29, 2009 | Juki TL-98Q
Juki TL-98QE thread comes out of needle, won't pull up bobbin
It can be many things but first make sure the needle is in correctly, follow the manual to be sure, if it still does not pick up the bobbin thread you may want to bring it to a repairman to see if it is out of timing.
Jul 06, 2009 | Juki TL-98Q
Needle thread breaks while quilting on machine frame
My friend and I both have the Juki 98Q but on different frames - we were both having problems (needles breaking, thread getting tangled) we removed the thin metal thing inside the bobbin case and have had no problems since (over a year now!).
Nov 01, 2008 | Juki TL-98Q
Sewing Machines Logo
107 people viewed this question
Top Juki Sewing Machines Experts
TCHNICAL SUPPORT FOR...
Tally Girl
Tally Girl
Wayne Buss
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
