SOURCE: Juki Sewing machine DDL-555. After 4-5 hours use feed not moving
Sounds like as the machine builds up friction from extended use, some vital part is lacking lubrication and is seizing up. A good service person will remove ALL of the covers and thoroughly air clean and oil every moving part. Sometimes these dry points are hard to find and patience is required.
You can get a sewing machine oiler with a long applicator and put a drop of oil on anything that moves, but over oiling can be messy.
SOURCE: how to fix timing on a juki ddl-555
Hi, if your ddl-555 sewing machine the needle doesn't grab the string from the top and bottom; and it can't sew the fabric. Do you know what to do/
SOURCE: Need parts/manual for old Riccar sewing machine
Here's a manual for the 551, it should be similar enough for your machine.
http://www.riccar.com/ftp/whitepapers/551-Owners-Manual.pdf
If not look on www.riccar.com/help/manuals for a similar model.
Find out what shank your machine is and you should be able to buy parts for it. I find ebay great for old sewing machine parts.
Hope this helps!
Hi valmyke ,
Plz try this link ..hope it works for you..if not kindly revert
http://content.janome.com/index.cfm/Machines/Retired/DE-PRO_5124
Thanx
