Hi Bonnie.
try this link and read what other people are saying about the problem you have.just scroll down on the page and read.
or this one.
Electric blanket error code
or this one.
Get F2 error code on sunbeam heating pad model cat93 contrller sw404
SOURCE: My Sunbeam electric blanket controls
Same problem, but now it is ok. I emailed Sunbeam and was told that if my blanket was not plugged directly into a wall outlet it was not getting enough power and I needed to plug it into a wall outlet taking these steps:
1) Unplug from the surge protector/extension cord
2) Unplug from the blanket
3) Plug back into the blanket
4) Plug into a wall outlet
SOURCE: my sunbeam electric blanket - the heat controller ...
do away with the blanket, as it is an electrical issue, hazard!
SOURCE: sunbeam electric blanket flashing ff
Ok folks. I fixed it. I unplugged and then waited and replugged and started at high or 9 and then it went to FF in 60minutes or a couple of minutes. I scratched my head and tried this fix--instead of starting again at 9 or H I started at level 7. That did it. FF most probably indicates excess current, and the H or 9 probably is too high to set. So unplug -repluf-turn on and dial 7 or lower. It should fix it. Or buy a new one.
SOURCE: need replacement control for sunbeam electric blanket
Take a look on amazon for it. here: Finally charging for our multi device world. I hope this helped you.
Simon
